Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 09-24-2018, 04:23 PM   #1
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
Default ECU Swap
I tried doing a couple different searches regarding swapping a 2004 RL ECU into a later year for the purpose of overcoming the 1st gear torque limitation.
Does anyone have any links or leads on whether the '04 ECU will swap in and relearn with the BCM without issues? I'd rather find a solution for defeating the speed limiter than dick around with the 50% throttle limit and no VTAK
Thanks guys.
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 09-24-2018, 11:06 PM   #2
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Default Re: ECU Swap
Just a thought, but if it’s a Honda J35, couldn’t you tune the PCM with something like Hondata, or is it a GM PCM that may not be tunable?
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
“Stock” is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 09-25-2018, 05:27 AM   #3
AlexofNazareth
2002 SL1
2006 VUE Red Line
GM used a Honda motor and trans, but it's run off GMs ECU. So it's completely different.
'06 Vue RL
Old 09-25-2018, 06:56 AM   #4
19boneatock88
2004 ION-2 Sedan
Does any tuning company offer support for the VRL?
EDIT: it appears the J35 uses the same E16a PCM that the 2.2 ION uses... :facepalm:
Jerama- WV
Old 10-12-2018, 04:41 AM   #5
Tobacconist
Tobacconist is on a distinguished road
No, the ECU is the same Motorola ECU as used in the Acura MDX.
Add to Tobacconist's Reputation
Rate the quality of this post and help Tobacconist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tobacconist is offline   Reply With Quote
Old 10-12-2018, 04:46 AM   #6
Tobacconist
They are completely different, just look at the connectors.
You can find good images of both on ebay.
Can I swap 2002 DOHC SC Auto trans swap into 2000 SOHC SL? fbr S-Series Tech 3 07-17-2014 10:08 PM
What's easier: 5th Gear Swap or full Trans Swap Tatohead S-Series Tech 6 07-30-2013 12:51 PM
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 05:45 PM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
96 SL1 w/ MP7 TRANS??? PLZ HELP!!! SWAP PCM FROM DOHC???? SWAP BOARDS??? randyshear S-Series Tech 20 11-15-2006 05:58 PM
