Old 11-28-2019, 12:11 PM   #1
homerec130
homerec130 is on a distinguished road
2008 VUE 3.6L
Default Directional Turns on High Beams
Figure I may have a short on the directional lever (stick or whatever it is called) on my wife's 2006 Vue. When she uses the directional, the high beams come on. Happens on either a left or right turn. The only way to turn off the high beams is return the stalk to the mid position and then turn off the high beams in the normal manner. To be honest, I haven't tried to see what happens if the hgh beams are on and use the directional.
When the directional is not in use, high beam switch works as advertised. Also, using the lane change feature has no effect on the high beams. For now, we just use the lane change feature at night so we don't blind folks with the high beams. Daytime is not an issue.
Looking for a ballpark idea as to what this will run as I don't want to spend any more on this car than I have to. It is my wife's car when I can't take her somewhere.
Many thanx,
Homer
Paul "Homer" Simpson
15 Ford Fiesta, Gray
06 Vue 3.5L, FWD, Storm Grey (Wife's Ride)
08 Vue 3.6L, FWD, Sunburst Orange - RIP 6T70
Add to homerec130's Reputation
Rate the quality of this post and help homerec130 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
homerec130 is offline   Reply With Quote
Old 11-29-2019, 01:16 AM   #2
tcndeb
tcndeb is on a distinguished road
2004 VUE 2.2L
Default Re: Directional Turns on High Beams
I would think it's the multi function switch. About a 35-40 dollar part at Rock Auto. Just replaced one in my daughter's 06.
'04 Base Model Vue, 2.2, 5 Speed
Add to tcndeb's Reputation
Rate the quality of this post and help tcndeb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tcndeb is offline   Reply With Quote
Old 11-29-2019, 11:48 AM   #3
homerec130
2008 VUE 3.6L
Many thanx. I will add it to the list of things to fix on this car. Still runs pretty good. Both back windows are pinned up and disconnected, just replaced the motor and regulator on the driver's window. No one rides in the back seat as they are usually flat. Still gets her where she she needs to go and passes emissions. Oh, and the radio works. :-)
2006 Saturn Ion 2 - High Beams Work, Low Beams Do Not. spacer7767 Ion General 4 10-31-2018 07:44 AM
Low Beams not working, DRL and high beams do josefvs L-Series Tech 2 08-03-2018 04:00 PM
High Beams indicator flickering, cutting DRLs, but no high beams andymcconnell L-Series Tech 6 10-04-2012 10:14 PM
Low beams on with high beams mod aaron7 S-Series Mods 12 07-10-2009 12:06 PM
High beams work low beams don't NateM137 S-Series Tech 5 09-01-2008 05:10 PM
