Old 08-24-2019, 02:56 PM   #1
MikeNW
MikeNW's Avatar
1997 SL
Default my piston "soak"
1997 SL
197,000 miles
It burns little oil, if any, probably because I used synthetic for most of its 22 years.
Anyway, While doing the head gasket repair, with the head OFF, I turned the engine so the pistons were all 1/2 way. Then poured Berryman B12(?) cleaner on each piston. Let it soak. Made sure it got between piston and cylinder, with a spatula. Did this for a week or so.
Then did the same with MMO. About 1/4 cup at most into each cylinder. Every once in a while, I turned the engine so the pistons went up and down.
Some yucky black glop drained from the empty oil pan. I was surprised.
Some cylinder(s) drained the B12 or MMO faster than others.
My cylinders were 185 psi for all 4 when tested this spring.
Maybe this can't hurt
08 Burgman 400
Add to MikeNW's Reputation
Starter relay violently failed, digital display reads "PWR STR" and "COOLANT" tb123a Ion General 6 10-24-2015 04:20 PM
Why not do a "soak" with carb cleaner or similar? dbvanw S-Series Tech 25 04-28-2011 03:29 PM
Vin "7" Vin "8" Vin "9" brake pads/rotors universal? demoncamber S-Series Tech 4 09-09-2009 12:35 PM
Where to buy "Total Seal" piston rings? meseville S-Series Tech 1 03-13-2007 06:21 AM
Those that have done the engine soak using GM "TEC" ... BlackGoldSL2 Miscellaneous Tech 17 11-11-2003 11:28 PM
