Old 08-23-2019, 02:22 PM   #1
prioris
prioris is a jewel in the roughprioris is a jewel in the roughprioris is a jewel in the rough
Default will this horn fit
Will this horn fit my 1999 Saturn Sl1
https://www.carparts.com/horn/replacement/repc502504
seems like a generic part
according to car parts, it says it is a fit it seems to fit a zillion cars
I just want to be sure it is a direct fit and there is no need to fabricate anything to get it to fit correctly
prioris is offline   Reply With Quote
Old 08-23-2019, 02:28 PM   #2
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Default Re: will this horn fit
No. You would need to modify the cars wiring and connector.
Your car should have the three wire horn. The local junk yard or ebay are your best bets if you want a drop in part.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Claybury is offline   Reply With Quote
Old 08-23-2019, 03:51 PM   #3
Yep, what Claybury said. It's not a matter of fitting, it's the electrical connections. The 3-wire horns have an internal relay that fails.
Richpin has a video up now (or did, several years ago), for the 3- to 2-wire horn conversion based in part or whole on something OldNuc posted a while back. It's not overly difficult and once you do that, you can use any 2-wire horn.
Old 08-23-2019, 04:32 PM   #4
Waiex191
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Waiex191's Avatar
Here is my horn fix:
http://www.saturnfans.com/forums/sho...&postcount=101
http://www.saturnfans.com/forums/sho...&postcount=103
http://www.saturnfans.com/forums/sho...&postcount=107
Or you can just go to page 6.
http://www.saturnfans.com/forums/sho...=234273&page=6
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 08-23-2019, 07:11 PM   #5
If you use an incorrect relay you will still burn out the clock spring and/or the horn buttons. This will happen immediately or last for enough time you think it is fixed. The richpin video has all the correct information on how to do this correctly.
Old 08-23-2019, 09:01 PM   #6
prioris
It's amazing they would even sell the part as a fit. Any link to a correct part.
Old 08-23-2019, 09:20 PM   #7
prioris
i don't want to mess with wires
this is what i found on ebay
https://www.ebay.com/itm/1996-1999-S...-/271300839839
i assume this will work
but this shows same part number
https://www.gmpartsdirect.com/oem-pa...-horn-21024585
but says will not fit
something i found on rockauto
More Information for ACDELCO 21024585
The ACDelco GM Original Equipment Replacement Horn is a GM-recommended replacement for your vehicle's original component. Activated within your vehicle's steering wheel, the Original Equipment Replacement Horn will make an audible noise at the front of your vehicle to signal or alert other drivers. This original equipment replacement horn has been manufactured to fit your specific GM vehicle, providing the same performance, durability, and service life you expect from General Motors.
heres amazon
https://www.amazon.com/General-Motor...999+Saturn+SL1
Old 08-23-2019, 09:29 PM   #8
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by prioris View Post
...Any link to a correct part.
Here is the part number, 21024585
https://www.gmpartsgiant.com/parts-l...eld-parts.html
Is there a way to test an S-Series horn in a salvage yard, besides hooking-up a 12-volt battery to the battery cables?
Old 08-23-2019, 09:38 PM   #9
prioris
amazon post ... same as OldNuc said
"The horn used on my 1996 Saturn Wagon is a very special 3 wire horn in which the relay is located within the horn. If you use a generic horn which is a 2 wire design you will destroy the horn contacts within the steering column due to the horn contacts having to handle the full horn current. You must use a 3 wire horn, and that's why I purchased this horn that is the OEM horn for my vehicle. Works great."
Old 08-23-2019, 11:10 PM   #10
You can probably build your own using the exact same part richpin used for less money.
Old 08-24-2019, 09:08 AM   #11
prioris
OldNuc ... i know but in the end, there is only a difference of around $15 dollars
... ease of installation is easily worth that ... i'm focused on getting my car to pass inspection and not worry about smaller stuff ... the really big cost for me was getting the underside of my car repaired ... i was picturing myself being like fred flintstone car and using my feet to drive the car ... lol
Old 08-24-2019, 09:51 AM   #12
As long as you recognize the differences then it is all up to you.
How to correctly wire 12v 40amp relay for air horn system from 3 wire horn connector? demoncamber S-Series Mods 2 06-20-2013 01:44 PM
horn trouble-no power to horn/not fuse 2xsl2 S-Series Tech 6 03-06-2010 11:32 PM
expiermented to day on 97 sc1 horn replaced with honda horn,whadda ya think! maestro S-Series Tech 1 07-27-2007 12:52 AM
VUE horn location - adding 2nd horn? Robert H. Vue Tech 3 09-11-2006 04:20 PM
Horn Dead, Its Not The Fuse , Cant Find Horn justinkr58 S-Series General 2 07-01-2005 06:39 AM
