Old 08-20-2019, 01:04 PM   #1
Keblar
Keblar is on a distinguished road
Idea 880 vs 893 Fog Light Bulbs or Something else?
I drove some very foggy dark mountain roads this past weekend and decided it was time to try new bulbs in the stock SL2 foglights. They've never been operable since the car has been in my possession and I've never bothered with them. They my not even function, but I'm hoping new bulbs are all that's needed. Maybe I'll check the voltage at the harness / socket if I find it's straightforward enough.
Anyway, search is failing me a little here. There's some mention that the stock 880 bulbs burn out too quickly and that stepping up to the 893 bulb is the solution, but that goes back 5 or even 10 years. Is that still considered a smart choice or is there even a newer alternative someone is aware of that hasn't gotten much mention? Do the 880's really have that high a failure rate?
I'm pretty leery of the increased Wattage and any extra draw on the system given the tendency to melt terminals. I feel like I've been pretty fortunate to avoid any electrical gremlins so far and I REALLY don't want to encourage any.
2002 SL2 305k + Miles
Keblar is offline   Reply With Quote
Old 08-20-2019, 01:16 PM   #2
Default Re: 880 vs 893 Fog Light Bulbs or Something else?
Looks like the 880 is 32w, the 893 is 37.5w and the 885 is 50w.
Other's with plastic housing's for the fog lights have them (885) work fine, I'd be more worried about the increased load on the factory overloaded wiring. I'd suggest using the factory circuit to turn on/off a dedicated (custom) power source for them.
Old 08-20-2019, 05:41 PM   #3
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Superbright LEDís has white 4000 lumen 880 ledsís.
RockAuto has yellow Hella 880 bulbs...
I like the yellow in fog...
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 08-20-2019, 07:37 PM   #4
Keblar
They're all low enough in price at RA that I'll just try out the Hella 880's for now. If they burn out I'll move up.
I'm still not sure I trust any of the LED bulb upgrades for the price. They all either seem too dim, too cycling prone, too short lived, or all 3, and not even for as cheap as the Halogens.
Old 08-20-2019, 09:27 PM   #5
Waiex191
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Waiex191's Avatar
Mine are useless. I'm not motivated enough to try new bulbs.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 08-21-2019, 08:21 AM   #6
Replacements that actually work are rather expensive and are a real pain to mount properly because you have to dismantle most of the front bumper structure to drill mounting holes. If you never have to drive in fog then skip them.
Old 08-21-2019, 08:26 AM   #7
bumpdraft
bumpdraft's Avatar
1998 SW2
Any suggestion on the relay we should use to power the 885 bulbs?
Like Waiex191ís, my factory stock fog lights are just decorative daytime running lights, part of the chickmagnet option package.
Old 08-21-2019, 09:25 AM   #8
Relay with a pre-made pigtail & connector <example> (that's a 5pin relay, you won't need the 87a pin for this)
If you want it removable from the car again without cutting up the stock wiring you'll also need a pigtail for the 880 bulb <example>
It'd also be a good idea to have a fuse for the new wiring "just in case" <example> (50w x 2 = 100w....100/12 = 8.33a so really only a 10a fuse is needed)
Then you just have to wire all those together with whatever length is required (guessing 2x 4ft and 4x 2ft sections) of whatever color you like wire (ideally each function is it's own color but it'd function fine with all colored the same).
The cheapest, most hacky way to do all that is to pull a relay from a parts car (any car with a relay), plug everything together with spade connectors and snip off the factory bulb pigtail. Coat with dielectric grease and cover with tape or slather hot-glue to give some weather resistance.
Old 08-21-2019, 12:25 PM   #9
Keblar
Are ALL the stock foglights useless then, even in the 3rd gen? The reflectors and lens look decent to me.
Is that why there's so much talk about mods and higher output bulbs? I thought it was just folks trying to squeeze more out of a design, not that the design is inherently so terrible that it's purely cosmetic.
I use the "driving lights" on my newer Hyundai quite a bit, both in poor vis and just to help spot potholes, and find them pretty useful (they are a focused design though.) That's what made me think of getting the SL2's operational again.
Old 08-21-2019, 12:42 PM   #10
The reflector is vapor deposited aluminum and the entire lamp is low temperature plastic. Install high output incandescent bulbs and it will melt them. The reflector is too small to be effective. As I said the small ones that look OEM that work are highly sophisticated and expensive. There are LEDs that will work and last but they get very hot as well.
I have made this mod and I can tell you that it is a bit difficult and eats up a fist full of dollars. A SL will be lower cost and work. A SC will be more mounting work and higher cost because of the lamp cost.
Old 08-21-2019, 01:50 PM   #11
Waiex191
Waiex191's Avatar
The fog lights on my 2006 Dodge Ram truck-a-saurus are awesome in fog and snow. I shouldn't say my SC2 lights are useless. They are good for plugging in my timer and cabin heater in the winter. Enough light to see what you are doing, no chance of being blinded.
Bryan Cotton
Old 08-21-2019, 01:56 PM   #12
My modded SC2 has excellent fog lights. Likewise the fog lights on my 94 F350 and neither are OEM anymore. The F350 are LED and other than being slightly larger than the OEM gen2 SC they would fit and function.
I live out in the middle of a large conservation area teeming with deer so good lights are required.
Old 08-21-2019, 04:38 PM   #13
Saturn Night
Happy Re: 880 vs 893 Fog Light Bulbs or Something else?
Chick Magnet package...... Lolololololol..........
Old 08-22-2019, 07:52 AM   #14
bumpdraft
bumpdraft's Avatar
1998 SW2
They werenít much good for that neither
Old 08-25-2019, 08:04 PM   #15
Keblar
Replaced bulbs. Nothing.
Switch does nothing.
Swapped horn and fog relays. Fog lights on, but won't turn off.
But horn still works.
Swapped Relays back... Same thing. Fogs are now on, but won't switch off.
They do turn off as designed when the High Beam is engaged.
I opened up the switch pod and cleaned the contacts on the module, but no change. I'll read more old posts after dinner to try and figure whether it's still a bad relay that's failed hot or the (unobtanium without buying the whole switch pod) on/off module.
Old 08-25-2019, 10:58 PM   #16
A description from the service manual for '02 SL2/SC2;
Fog Lamps
Battery voltage is applied to the fog lamp switch from circuit 1200. The fog lamps will only come On when the headlamp switch is in the ON or PARK position, and the fog lamp switch has been pressed on. The fog lamps will not come On when the high beam headlamps are On. The fog lamp switch will energize the fog lamp relay by providing ground through circuit 317. This ground will also turn on the fog lamp indicator located in the fog lamp switch. When the fog lamp relay is energized, current will flow to the fog lamps through circuit 34. The fog lamps are grounded by circuit 150 through the forward lamp ground splice pack.
Below is a wiring diagram.
Tags
bulbs, fog lamp, fog light, foglights
Light Bulbs TXSaturn02 S-Series General 2 12-06-2010 10:28 PM
What light bulbs for third brake light? SRGW S-Series General 5 03-12-2006 03:54 AM
Map light bulbs? ProDarwin S-Series General 2 08-09-2004 05:37 AM
light bulbs cleansl2 S-Series General 3 11-03-2003 04:14 PM
Goo where my light bulbs are... jeepcat S-Series General 5 08-26-2003 10:22 AM
