Old 08-19-2019, 07:06 PM   #1
SlayZombi
SlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the rough
2001 SL
Post SOHC to DOHC Swap
Yes, another SOHC to DOHC post. I've looked at some posts but I'm hoping to get a more concise answer, more of a checklist actually. I've got a 2001 SL with the manual transmission in it. I simply want to do the most cost effective swap. I do not really have the tools to rip out the entire engine so I was hoping to leave the block in (SOHC and DOHC blocks are the same yes?) and change out the head and valve cover. Other than the head, valve cover, exhaust manifold, and oil pan, is there anything else I need or is that it?
SlayZombi is offline   Reply With Quote
Old 08-19-2019, 09:12 PM   #2
billr
Default Re: SOHC to DOHC Swap
Well, add to that list the timing cover, timing chain, and all that good stuff. I think the exhaust pipe below the manifold has to go or be weld-modified. How about the intake manifold? I would expect that also has to change; no guess on the ducting going to the TB. I can't think of any reason the oil pan would be different, but the spark-plug wires are. Oh... and the PCM, don't forget about that.
Old 08-23-2019, 03:45 PM   #3
Highmile
Highmile's Avatar
the swap is more than just swap heads and intakes.
Among things that are different, besides what was already brought up, the pistons are different.
So get ready to pull that block out if you want to do this.
Highmile
'95 SL1 692k and counting
Old 08-23-2019, 08:46 PM   #4
SlayZombi
2001 SL
Well now it needs a new clutch so this idea is dead, probably forever. lol
Can I swap 2002 DOHC SC Auto trans swap into 2000 SOHC SL? fbr S-Series Tech 3 07-17-2014 10:08 PM
sohc to dohc swap dohc from sw to sl 2002 MCDOWECT S-Series Mods 5 06-11-2013 05:06 PM
dohc swap to sohc samsr S-Series Tech 20 12-16-2007 12:43 PM
SOHC to DOHC swap How-To? tristanlee85 Miscellaneous Tech 2 08-28-2004 05:52 AM
SW1 SOHC to DOHC swap done! Low Saturn Mods and Performance 17 12-26-2003 12:00 AM
