Old 05-10-2019, 11:40 AM   #1
rubberband man
rubberband man is on a distinguished road
Default amient temperature sensor location on 2008 saturn vue
I am looking for the location of the ambient temp sensor location on a 2008 Saturn Vue 4 cylinder. Thank you
rubberband man is offline   Reply With Quote
Old 07-09-2019, 11:35 AM   #2
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
2008 VUE 2.4L
Default Re: amient temperature sensor location on 2008 saturn vue
In front of the radiators, between the radiators and the bumper skirt. If you look down from the top you can see a tiny thing with 2 wires going into it.
Peter
CURRENT:
08 Vue XE Black 2.4L
07 Ion 3 Savannah Green Metallic 2.4L
04 Ion 2 Berry Red 2.2
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
95 SL2 Lilac Metallic
94 SW2 White
hudypete1 is offline   Reply With Quote
Old 07-09-2019, 01:57 PM   #3
hudypete1
2007 ION-3 Sedan
2008 VUE 2.4L
It is in the same mini-wire harness with the hood-latch-closed sensor. Just follow those wires straight down.
One of the wires to the ambient temperature sensor is green, the other is yellow.
I believe that most temperature sensors from other GM cars (at least) will function the same in case you had to go to a junkyard and try to find one, but couldn't find a Saturn vue. For a buddy, we installed one from a Malibu and it seemed to work just fine.
Peter
CURRENT:
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
94 SW2 White
2008 Saturn Vue XR 3.6L Power Steering Cooler location phaxmohdem 2008 Vue 2 11-06-2018 07:22 AM
2008 Saturn Vue Purge valve canister solenoid location iobrien Vue Tech 10 08-11-2016 12:40 AM
2003 Saturn Vue Ambient Temperature Sensor Gubler Vue Tech 3 05-22-2013 01:42 PM
Outside Air Temperature Sensor Location? ud503j Vue General 3 08-24-2006 10:24 PM
ECTS Temperature & PCM coolant Temperature sensor Matt_Agate S-Series General 6 02-03-2006 08:16 PM
