Old 08-23-2019, 07:42 PM   #6121
Eschmitt
Eschmitt is on a distinguished road
2002 SL1
Default Re: What did you do to your S-Series today...
Busy few days
Started with a change of oil, transmission fluid, and a brake bleed. Ended the day with a coolant drain and put a coolant flush in with some distilled water.
Let that sit for 2 nights then drained it and put in 3.78 L of pure coolant and topped off with distilled water.
Makes me feel a lot better about the new Saturn. It's running smooth and shifting a lot better.
Probably do the spark plugs and wires next.
Eschmitt is offline   Reply With Quote
Old 08-24-2019, 01:29 PM   #6122
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Pulled my first valve body today off an SL1 down at the you pull it. Going to test the solenoids tomorrow but at least the connector doesn't have any burnt terminal ends....and it only cost $20. Fingers crossed!
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
jpags729 is offline   Reply With Quote
Old 08-24-2019, 07:09 PM   #6123
Replaced the trailing arm. Took it off last weekend, put new one on this weekend.
Removal - ran in to the same problem as the guy in the link I posted earlier. I'd bought a cheap Chicago electric impact several years ago, mostly to speed up removing lug nuts. With the rust, it had no effect on the trailing arm bolts,.
Was considering giving up and taking it to a shop like the other guy did, got to mentally comparing shop rates ($130 hour) and likely inflated parts cost (probably $130~150 for the arm) and decided to look at compressors even though it would mean cleaning my garage to make space.
Came across another electric impact by Bauer, supposedly 5x the torque of the Chicago,. Bought that for $90. Hit it several time, bolts loosened up. Was going to run out to the store to buy an arm but it was getting late, decided just have one shipped and save ~ $10~15.
Dorman part had all the coating all worn off the mounting tabs. So I decided to paint the ends with leftover POR15. Sprayed the rust around the mounting area and undersides with rust converted, put on trailing arm.
Had to use a C clamp to pull the knuckle forward enough to get the rear bolt on but other than that, went pretty smoothly.
Wife is happy to have her minivan back.
Old 08-24-2019, 11:47 PM   #6124
focusofheart
Originally Posted by alordofchaos View Post
...Wife is happy to have her minivan back.
"Happy Wife, Happy Life!"
Saturn 1998 - SL2 automatic
Old 08-25-2019, 01:11 AM   #6125
98_Gold_Uranus
98_Gold_Uranus's Avatar
Installed version 2.0 of my 3D printed cell phone holder.
This time with a slot built in for a cheap wireless charger that can be bought at the store 5 Below for just $5
Old version was just stuck on with adhesive velcro, but the adhesive proved to be inadequate in the Florida heat... so this one mounts with 2 screws, it's NOT falling off!
Her name is Uranus :)
Old 08-25-2019, 08:48 AM   #6126
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: What did you do to your S-Series today...
Search for F5 failure. Just a word of caution noticed you are using the lighter to power 2 chargers. The lighter use in this fashion can cause failure of the F5 in the passenger fuse panel and can cause failure of the fuel pump relay 12 volt supply. I cut the 12 volt supply line to lighter and ran a fused line from the under hood fuse/battery to the lighter.
1995 SL1 236,300 2005>2018
1997 SL1 77,300 2014>????
CHECK YOUR OIL!!
SRGW is online now   Reply With Quote
Old 08-25-2019, 12:16 PM   #6127
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by SRGW View Post
...I cut the 12 volt supply line to lighter and ran a fused line from the under hood fuse/battery to the lighter.
CHECK YOUR OIL!!
Yes, I did the same. And it would be super easy for someone who designs and manufactures custom, marketable 3D printed accessories.
Old 08-25-2019, 01:13 PM   #6128
Yep, F-5 failure in progress. You may end up searching for a replacement I/P Panel and they are getting rare and expensive. iPhone is a major power pig.
Old 08-25-2019, 01:52 PM   #6129
98_Gold_Uranus
I plan on wiring in a second outlet under the dash that's only on with accessory and using that. Or just using one of the extra USB ports on the back of my Android radio to power it, that would be even easier...
Old 08-25-2019, 02:12 PM   #6130
jpags729
jpags729's Avatar
Tested all the solenoids and all were between 5.5 and 6.0 so it looks good. Can anyone post a pic of how the manual valve is supposed to sit in the valve body? Does the plastic tip sit facing towards the front of the car? Thanks!
Current:
Previous:
Old 08-25-2019, 08:03 PM   #6131
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
There is only one way that the small bent metal bar fits into the bigger bar that comes out of the bottom of the valve body. It helps to slide out the bigger bar slightly so that you can insert the small metal bar into the bigger bar. FiremanCV has a video on YouTube for this.
https://www.youtube.com/watch?v=cwV4TPL3TDg
edlee is offline   Reply With Quote
Old 08-25-2019, 09:52 PM   #6132
jpags729
jpags729's Avatar
Thanks edlee!
Current:
Previous:
Old 08-26-2019, 10:29 AM   #6133
RicanSC-2
RicanSC-2 is on a distinguished road
Changed the ECTS on my SC-2, my gauge was reading a little over the first mark, some time went a little higher but not to the middle mark.
RicanSC-2 is offline   Reply With Quote
Old 08-26-2019, 10:30 AM   #6134
Those 3D printed accessories are fantastic!
I agree, but to hear some divorced guys on car forums speak . . .
their wives were only happy if the guy was miserable
Old 08-26-2019, 10:40 AM   #6135
focusofheart
That is why they are divorced
Selfishness is the route to most personal problems to me and if the wife was only happy when the husband was miserable - that's selfishness in my opinion.
To me it actually goes both way - "Happy Husband, Happy Life!"
Old 08-26-2019, 02:00 PM   #6136
trottida
trottida's Avatar
If the radio is powered by a stock circuit then there is a flaw in this thinking. The proper way is to run fused power from the UHJB (or battery) and use a switched relay to control it. Check out how in this post ... http://www.saturnfans.com/forums/sho...69&postcount=8
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 08-26-2019, 11:04 PM   #6137
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
I got another Rock Auto magnet. Need something to lure the kid home from college sometime. We noticed he needs new pads and rotors last oil change.
I had grabbed the hardware to mount the jack. So I pulled out the spare. Looks like I get to change another one.
Also noticed a bunch of water on the driver's side.
I punched a #30 hole so it will auto-drain.
Old 08-27-2019, 09:39 AM   #6138
Wow, don't think I've ever seen a spare like that.
#30 auto drain will work, but pulling the rear quarter panel and re-sealing the seams can be done in in an afternoon
http://www.saturnfans.com/forums/showthread.php?t=78228
I already have some kind of plug/gasket back there that a wire goes through (circled in your pic), similar to what your pic shows, so my driver side already auto-drains when the water gets above the height of the plug.
Now I wonder if the PO cut the hole or if there is a difference between 2nd and 3rd gens?
Old 08-27-2019, 10:43 AM   #6139
454cid
That's the same magnet I got recently. In fact I got two. Which rotors/pads did you get? I bought the $10 Raybestos R series, and some sort of Raybestos pad... I think ordered R-series, but the box said something else.
My spare looked similar when I got it. The hole wasn't as big but still a hole, and not a puncture from a screw or nail. I just picked up a steel 14" rim with a tire, from the salvage yard.
1999 Chevy K3500
Old 08-27-2019, 11:40 AM   #6140
focusofheart
I have been wondering for a long time - is it because I live in California that I have ALOT less complications with my Saturn? or because I have my mechanic LOOK for possible problems?
No matter what, I am Blessed.
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
