Old 08-23-2019, 11:14 AM   #1
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Default PCV elbow for fixed orifice Fram PCV
Good morning everyone:
I recently decided to switch to the fixed orifice PCV valve and bought the Fram Fv410. Upon going to make the switch, I noticed that the OEM style one in there had the plastic elbow on it to go into the pcv hose. A few questions:
1) Is there a way to remove this plastic elbow without breaking it/rendering it useless?
2) If question 1 is no, do they sell a version of the plastic elbow? Part #? (Autozone says there isn't one for the saturn but they do sell a variety of general dorman ones)
3) On rockauto, up to the 1996 model year, they list out the Dorman grommet 42341 and AC delco hose 21007297, but they are not listed for the 1999 model year which I have (built in Feb 98 so gen 2 style engine before changes made). Will buying this hose solve the issue of the plastic elbow and will this grommet fit?
Appreciate it and a great weekend to everyone!
https://www.rockauto.com/en/catalog/...on)+hose,11784
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
jpags729 is offline   Reply With Quote
Old 08-23-2019, 11:37 AM   #2
Default Re: PCV elbow for fixed orifice Fram PCV
#1 yes hair dryer on high or heat gun set for 180F or so.
#2 Do not ever tell the counter guy what you are using a part on when you give them a part number. If you do you will get all kinds of bad info.
#3 all 99 model year Saturns have the narrow head engine. If you relly want to check match the dash VIN plate to the engine vin stamping and they better match. The PCV grommet will fit. Feb 98 build date would be a 98 model year car.
Old 08-23-2019, 02:23 PM   #3
jpags729
jpags729's Avatar
Thanks for the help OldNuc. I only checked Autozone's website so don't worry wasn't actually gonna ask for the info from them lol. I mistyped and wrote 98 instead of Feb 99. Just wanted to make sure the new grommet would fit. I guess the Delco hose with the clamps won't fit though due to the narrow head engine? I watched Richpin's video and he has that version of the hose and I believe he was working on his blue 98 SL2. It looks like that hose has the necessary elbow built into it, only reason I'm asking. Thanks again.
Current:
Previous:
Old 08-23-2019, 02:51 PM   #4
There are molded hoses with an elbow in them or you can find the generic nylon elbows and use a straight piece of hose. This can turn into an arts and crafts project.
Old 08-24-2019, 10:03 AM   #5
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Look on Rock Auto under other years...
I see some with the elbow under 2002...
This is true for many parts,
looking under SC, SL or SW,
and/or a different year
can yield more results...
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 08-25-2019, 02:10 PM   #6
jpags729
jpags729's Avatar
Well followed your advice OldNuc and used a hair dryer to the old AC Delco version with the plastic elbow and got it off with no trouble. Fram PCV is now in and hopefully curbs my oil burning. Thanks again!
And I did pull the older style pcv hose from a 97 SL2 down at the junkyard and it did not sit right as it was about 1/2 inch too short and this caused the pcv valve to sit at an angle. That's when I decided to heat the other one and keep the current s shaped hose. Basically was an arts and crafts project haha!
Current:
Previous:
Old 08-25-2019, 04:04 PM   #7
Yes, I have made several of those hoses fit nicely.
Engine Light after Fixed Orifice PCV? Help! Tommie S-Series Tech 8 01-18-2013 12:29 PM
fixed orifice PCV valve part #'s fetchitfido S-Series Tech 21 02-10-2012 01:38 AM
Fixed orifice PCV = bad mileage? Falcon4Christ S-Series Tech 11 08-14-2011 05:16 PM
Cracked PCV elbow hholbein S-Series Tech 12 07-21-2011 12:05 AM
Fixed orifice PCV in SW2? SL2Many S-Series Tech 3 06-10-2011 10:19 AM
