Old 08-13-2019, 06:19 PM   #1
NFSmaster16
NFSmaster16 is on a distinguished road
2001 L-Series 2.2L Sedan
Default Axle Seal
I was just wondering if anyone knew how the get the inner axle seal off without having to take out the transmission.
Thanks in Advanced
Add to NFSmaster16's Reputation
Rate the quality of this post and help NFSmaster16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NFSmaster16 is offline   Reply With Quote
Old 08-14-2019, 04:57 PM   #2
floridasl22002
Default Re: Axle Seal
Can you be a little more specific please?
On the outside of the transmission on both outputs, there is an oil seal each side. To replace that you remove it with a screwdriver or pick tool, then carefully insert the new seal, then tap it into place. you can use the old seal as the piece to tap against, therefore avoiding damaging the rubber seal.
If you mean the seal/bush that fits on the stub axles, then you have to remove the stub axles.
Neither of these jobs requires removing the transmission. You will however need to remove the respective drive shaft in order to replace the Seal.
How do I know? Just had these all done last week when the garage replaced the drive shafts on my son's L300.
Old 08-14-2019, 07:20 PM   #3
NFSmaster16
Im a little late on the response, but Thanks! My Dad went at it with a hammer and small chisel I believe and got it out. He always finds a way to take things out that usually require more work than usual.
axle seal jcable2 Ion General 7 01-25-2016 10:17 PM
axle seal dude33333 S-Series Tech 17 08-23-2015 10:59 PM
Replace Axle Seal While Replacing Axle? Keblar S-Series Tech 1 10-18-2012 03:35 PM
Do I have the right axle seal? turbobuick33 S-Series Tech 10 07-08-2008 08:14 PM
Axle Seal SL2Dreams S-Series Tech 5 09-19-2005 08:50 AM
