Old 09-26-2005, 09:25 PM   #1
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
Default So it begins: Rebuilding a 1995 SC2
If you recall I purchased a '95 SC2 with approx. 100,000 miles from an unknown individual for $650. Basically, I plan to do a complete teardown and turn it into a beast. I have a '96 SC1 (which was been very good to me thus far) for my daily driver. If I have the necessary funds, time and knowledge, I plan to forge this baby and drop in a turbo.
I have a pretty decent garage with a fair amount of tools and a credit card for the tools I will need but don't have I am gonna hold on the engine hoist and stand until I get to the point where I actually need it. I plan on picking up FSMs from my local dealer sometime in the upcoming weeks.
Bear with me here. I am very busy with school and work on the weekends, so its gonna be a slow process. I will use any free time I have to get this project going, and be sure to take pictures. Unfortunately I dont have a dedicated digital camera, so I'll be using my Sony Ericsson Phone.
1996 SC1
Add to RalliArt16's Reputation
Rate the quality of this post and help RalliArt16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RalliArt16 is offline   Reply With Quote
Old 09-26-2005, 09:38 PM   #2
RalliArt16
RalliArt16's Avatar
1996 SC1
Default Re: So it begins: Rebuilding a 1995 SC2
Day 1:
Pulled the car inside and took the hood off.
Took out the plugs to inspect them. Plugs from cyl's 2 and 3 were covered in oil, it was literally dripping off them. I suspect a cam cover gasket, no big deal.
Proceeded to remove front fenders, front bumper. Car placed on jackstands and wheels removed.
I was suprised at the tires. One tired was bald down the metal wire. The other 3 looked new but each tire was different from each other....
I was a little irritated when I realized a plastic bracket from the front bumper was snapped off. It looks like he had a little fender bender which caused this. This would also explain the broken bracket for the turn signal.... Luckily no other major damage is done. How much is a new bumper gonna run me?
Note: Am I missing something here or can you only upload 1 image at a time. Its very time consuming and annoying
1996 SC1
Old 09-27-2005, 12:31 AM   #3
RalliArt16
RalliArt16's Avatar
1996 SC1
A new front bumper from saturn is $300+ ! I'm gonna see if i can repair this one. The mounting piece is a plastic part that snapped off and I have the piece.
What would someone recommend as a permanent, strong way to join two pieces of plastic?
1996 SC1
Old 09-27-2005, 02:17 AM   #4
ArghIGiveUp
Guest
Posts: n/a
Take the bumper to a business that specialises in bumper repair and reconditioning. They can weld plastic. No adhesive I have ever found works worth a hoot at holding the tab to the rest of the fascia at the spot right by the corner of the corner lamps. I had the same kind of damge on my car, and I wasted six months and too much money trying to glue it together with $60 adhesive kits, etc.
Add to ArghIGiveUp's Reputation
Rate the quality of this post and help ArghIGiveUp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-27-2005, 11:57 AM   #5
Low Saturn
Low Saturn's Avatar
2000 SC2
jjbumpers.com had reconditioned bumpers at pretty decent prices.
Old 09-27-2005, 03:01 PM   #6
RalliArt16
RalliArt16's Avatar
1996 SC1
After inspecting it closer and referring to saturnpart.net, it seems the broken part is actually removable and replaceable. Its #10 is this image,
http://www.trademotion.com/schematic.../I/IA91910.gif
the "lower support fascia". And its "only" $45
1996 SC1
Old 09-28-2005, 02:10 AM   #7
RalliArt16
RalliArt16's Avatar
1996 SC1
Ok, so i've done a little more removal of parts. Now planning to attack the A/C. I plan on totally stripping the car of A/C (even tho I do live in Florida..). Obviously I can't get the car to a professional A/C shop. With that in mind, what is the next best thing to remove the refrigerant from the a/c system? Is there an alternative to purchasing a vacuum pump?
I'm open to suggestions, even if it involves ghetto rigging something. Anything is better than simply letting it all into the atmosphere.
1996 SC1
Old 09-28-2005, 08:03 AM   #8
PeteB
PeteB is on a distinguished road
PeteB's Avatar
2002 L-Series 3.0L Sedan
1994 SC2
A home or appliance A/C repairman can remove the refrigerant for you. Try calling your city hall, to find out what they do with old refrigerators and A/C units.
Add to PeteB's Reputation
Rate the quality of this post and help PeteB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PeteB is offline   Reply With Quote
Old 09-28-2005, 09:50 AM   #9
dixonba
dixonba is on a distinguished road
dixonba's Avatar
2007 ION-2 Sedan
pssssssssssssssssssss...
Add to dixonba's Reputation
Rate the quality of this post and help dixonba reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dixonba is offline   Reply With Quote
Old 09-28-2005, 11:45 AM   #10
eljefino
eljefino's Avatar
1995 SW1
If it makes you feel better the 134A in your year is ozone friendlier...
Still illegal to vent it but it was designed from the ground up to be nice to the air.
Add to eljefino's Reputation
Old 09-28-2005, 04:22 PM   #11
RalliArt16
RalliArt16's Avatar
1996 SC1
LOL.... it is only 1.5 lbs after all... Dunno have to think about it. Just think though, at work (advance auto) we sell ridiculous amounts of R134a to DIYers.. just imagine how much they are dumping because of leaks in their systems, and simply keep refilling it instead of getting it repaired.
1996 SC1
Old 09-28-2005, 04:29 PM   #12
RalliArt16
RalliArt16's Avatar
1996 SC1
Heh i just went out and started unbolting the A/C lines.. and nothing came out! Guess the system was bone dry already due to a leak somewhere.
1996 SC1
Old 09-28-2005, 06:35 PM   #13
RalliArt16
RalliArt16's Avatar
1996 SC1
Update as of today:
Got the a/c compressor out, coolant / wiper fluid reservoir out, and a few other misc things.
Came across the nice suprise that the passenger's side CV joint is totally mangled. The driver's side joint looks identical...
1996 SC1
Old 09-29-2005, 12:52 PM   #14
paradigmdream
paradigmdream is on a distinguished road
1994 SL1
i'm thinking about picking up an SC2 and rebuilding too. are there any years i should stay away from?
Add to paradigmdream's Reputation
Rate the quality of this post and help paradigmdream reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paradigmdream is offline   Reply With Quote
Old 09-29-2005, 01:31 PM   #15
mars_volta
mars_volta is on a distinguished road
mars_volta's Avatar
curious why you are removing everything? if you need a weight reduction guide go here:
http://www.evilplastic.com/p92-wgt1.htm
2005 Legacy GT LTD
94 SL2
95 SC2
Add to mars_volta's Reputation
Rate the quality of this post and help mars_volta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mars_volta is offline   Reply With Quote
Old 09-29-2005, 03:05 PM   #16
RalliArt16
RalliArt16's Avatar
1996 SC1
Why am I removing everything you ask? It is going to get a new paint job. At the moment I am an amateur painter however. I purchased a few books on automobile painting and will invest in a very good compressor + painting tools. Plus the great part about saturns is that every panel comes off except the roof.. which will make painting them immeasurably easier.
Not to mention taking everything off makes access to things a lot easier, plus it pisses my parents off more
1996 SC1
Old 09-29-2005, 03:08 PM   #17
RalliArt16
RalliArt16's Avatar
1996 SC1
By the way, I will attempt the crank pulley today. Going to pick up some impact sockets + some piping to use as a cheater bar. However, what is the best way to keep the crank pulley from rotating as i undo the bolt?
I would think you just put it in gear, however.. the tranny is shot so it won't engage into gear... I guess i'm gonna have to try to wedge something in between the pulley to hold it steady. Any other ideas?
1996 SC1
Old 09-29-2005, 03:42 PM   #18
2NDSOUT
2NDSOUT's Avatar
1999 SL
I'm rebuilding a 91 SC. Pics in my gallery.
I noticed from the 91 to my 94 that some of the bolts they decided to use are different. For example...the interior bolts to remove the front right fender on my 91 were the Torx-T-27 bolts. On my 94 SC1 they are either 10MM or 13MM bolts.
I guess that goes to show you how they change things from the beginning.....
I need to get back to working on my car....I haven't devoted any time to it recently. I've kind of been involved in work and spending free time with my wife and our dog....
Maybe I'll do some work on it this weekend.....
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 09-29-2005, 04:04 PM   #19
dixonba
dixonba's Avatar
2007 ION-2 Sedan
That was my first attempt. Just replace tire iron with impact wrench...
Old 09-29-2005, 05:02 PM   #20
RalliArt16
RalliArt16's Avatar
1996 SC1
Heh i'll have to rig something similar. Taking off the crank pulley has been put on hold for a while however. I have large craftsman sockets but they're 12pt.. (after contacting craftsman, they dont have 6pt sockets in 20mm and above.. because the "12mm sets sell better" ). I dont have an impact wrench at the moment, but i can purchasing them because 1) they're 6 pt and 2) i will buy an impact wrench in the future. I just ordered a set of metric impact sockets online from sears.com. They dont have large sets at my local sears store and its $10 per socket... so i opted to just order a set.
1996 SC1
Rebuilding 95 DOHC SC2 RichBrown S-Series Tech 374 07-15-2015 01:47 AM
Here's Where The Fun Begins Racer93 S-Series Tech 5 03-15-2008 09:35 AM
Rebuilding The SC2 and Want Advise For The SL2 Red Sc2 S-Series Tech 8 10-04-2007 10:23 AM
Supercharger project begins! plastic torpedo S-Series Mods 91 08-11-2007 01:05 PM
the door makeover begins! BlueIonDriver Ion General 31 05-06-2004 11:20 AM
