Old 05-23-2019, 04:16 AM   #1
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Default Unplugged IACV, no fault code?!
Basically the car has had a “rev hang” as you shift for the longest time and I seen someone else work around it by unplugging the IACV at idle and I tried it with success, or at least it doesn’t rev hang as I shift anymore... what’s surprising however, is that the CEL hasn’t come on yet... no pending codes or anything. I figured that when you remove the PCM’s ability to regulate idle it would throw a code, much like a toddler throws a tantrum when you take its toy lol... I’ve driven 160mi since unplugging it and so far the only negative is idle dropping to like 450 with AC on... (easy solution, don’t use AC lol)
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
“Stock” is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 05-23-2019, 11:49 AM   #2
Default Re: Unplugged IACV, no fault code?!
Was throttle ever cleaned?
Old 05-23-2019, 04:49 PM   #3
19boneatock88
2004 ION-2 Sedan
Throttle was cleaned when I did the port and polish about a year ago. Since I vent PCV to atmosphere there is no oily gunk in my TB
Jerama- WV
Old 05-23-2019, 05:06 PM   #4
Being unable to see this mod, its presumed the pcv hose venting is diverted somewhere. Is the throttle port where the pcv hose plugged? If it was plugged, is it permanent or semi with the possibility of the plug loosening, falling off? If the port is open then this may be the source of extra air keeping idle higher than normal.
Old 05-24-2019, 01:35 AM   #5
19boneatock88
2004 ION-2 Sedan
The PCV tube was just removed from the factory air intake tube and vented to open air... I disconnected the idle air control circuit recently... maybe the actuator for the valve was sticky or maybe the car is just tuned that way for emissions purposes but in really surprised that the CEL hasn’t come on since I disconnected the plug to the IAC valve
Jerama- WV
'94 SL2 Code 32 - EGR fault jdk022 S-Series Tech 1 12-23-2011 06:17 AM
Code 26..QDM Fault...Still..... LvnInPeace S-Series Tech 1 10-17-2009 02:58 PM
ABS fault code 57 sPuddingTime S-Series Tech 2 12-15-2006 12:50 PM
95 SL1 Code 26 Fault TOmsterT1 S-Series Tech 6 12-30-2005 06:55 AM
egr fault code chadzilla S-Series Tech 1 10-31-2005 11:06 AM
