Old 05-22-2019, 09:30 AM   #1
Coehawk
Coehawk is on a distinguished road
Coehawk's Avatar
1999 SW2
Default windshield washer pump won't stop
Just started today. Windshield washer kept spraying until reservoir ran out. I could still hear the motor operating until I got home.
I'm sure it's just a relay switch or something, but short term can I just disconnect that plug attached to the reservoir?
Thanks
Add to Coehawk's Reputation
Rate the quality of this post and help Coehawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Coehawk is offline   Reply With Quote
Old 05-22-2019, 09:43 AM   #2
trottida
trottida's Avatar
Default Re: windshield washer pump won't stop
That or pull the fuse in the IPJB. You'll loose your windsheild wipers though as they are on the same circuit. If you pull the connector it may be a good idea to wrap it to keep moisture out.
2001 SL1 MT (433,500 km @ 06/2019)
1999 SL2 MT (277,300 km @ 06/2019)
2011 Suburban LT (128,250 km @ 06/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 05-22-2019, 10:31 AM   #3
Coehawk
Coehawk's Avatar
1999 SW2
Sounds like a plan.
Děkuji
Old 05-22-2019, 06:36 PM   #4
Coehawk
Coehawk's Avatar
1999 SW2
Worked like a charm. Thanks again.
I probably should have said this is a 1995 SL1, with ~222,000 miles. I guess things like this will happen.
Old 05-22-2019, 08:33 PM   #5
The pump control is part of the entire motor system. You can try cleaning the connector and socket and it might fix it or just replace it now and avoid the rush later.
Old 05-23-2019, 07:51 AM   #6
trottida
trottida's Avatar
I'm pretty sure OldNuc's referring to the windshield wiper motor located under the cowl at the bottom of the windshield. On the motor is a controller unit that causes all sort of issues when it's on its way out. To remove it you need to take the top of the dash off to access the nuts that hold the wiper assembly in.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Windshield Washer pump where to get? ZepSL2 S-Series General 6 01-30-2015 08:03 AM
Windshield washer pump carfreak09 S-Series General 5 08-12-2014 08:09 AM
Windshield washer pump PaulR Astra General 7 04-15-2014 01:43 PM
Windshield washer pump for 01 SL2 Dave3 Classifieds 0 04-07-2014 06:33 PM
Windshield washer pump jamur87 S-Series Tech 2 12-23-2004 10:39 AM
