View Poll Results: How long does it take to break in new Spark Plugs?
1 week 0 0%
5 minutes 0 0%
1 month 0 0%
till they don't work anymore 1 100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 05-18-2019, 09:52 PM   #1
Samtherecordman
Samtherecordman is on a distinguished road
Samtherecordman's Avatar
2007 ION-3 Quad Coupe
Default Replaced Fuel Injectors....Do I Need to do Fuel Trim or Reprogram ECM???
Replaced Fuel Injectors with New AC Delco....Do I Need to do re do Fuel Trim or Reprogram ECM at the dealer??? or the ECM will self adjust?
Also
When you install new Spark Plugs Denso Iradium TT , is there a "Break In" period from your experience???
Thanks,
Sam Man!
Saturn Ion 3 Quad Coupe 3 with Sports Appearance package with Aura Pro Bass Shakers under the front seats, Kenwood Excelon Mono Amplifier and Infinity Kappa Perfect and I'm In Heaven!!!!
Add to Samtherecordman's Reputation
Rate the quality of this post and help Samtherecordman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Samtherecordman is offline   Reply With Quote
Old 05-23-2019, 04:08 AM   #2
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Default Re: Replaced Fuel Injectors....Do I Need to do Fuel Trim or Reprogram ECM???
I’ve never heard of a spark plug break in, and as long as you went same size on the injectors it will be totally fine, the PCM will very quickly learn the difference between old and new
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
“Stock” is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 05-23-2019, 11:46 AM   #3
Technically, fuel injectors are controlled by the ecm and the ecm varies injector pulses from sensors. The upstream O2 sensor on the exhaust manifold measures oxygen in the exhaust and feedback signals to the ecm controls injector timing for optimum fuel/air ratios. As soon as the engine's started, the ecm automatically adjusts injector pulses immediately as if nothing was done. Sensors are feeding signals continually for the ecm to adjust spark and injector timing. Injector pulses vary all the time. Spark plugs do not break in. Presuming new ones weren't dropped during assembly, shipping, stocking shelves, and removed from their cardboard boxes, spark plugs are preadjusted with the correct gap for immediate installation. Undamaged plugs go in with startup imperceptible from previous plugs (unless the old ones were severely worn or damaged).
It can be said that spark plugs and injectors are truly plug n' play items. Replacing them can result in improved instant startups with smoother idling.
Saturn SC2 with P0171. Replaced Fuel Pump and Fuel Filter. Natelancer S-Series Tech 13 03-16-2017 05:13 PM
How do these fuel injectors look? BobbyBeans S-Series Tech 7 06-30-2010 02:23 PM
swapped in new injectors, no fuel to fuel rail! DJboozeAlot S-Series Tech 6 06-05-2009 04:10 PM
fuel injectors snowwhite Ion General 10 06-22-2007 08:11 AM
fuel injectors redrider0104 Ion Mods 4 05-23-2007 07:20 PM
