Old 03-20-2018, 01:10 PM   #61
that1man
that1man is just really nicethat1man is just really nicethat1man is just really nicethat1man is just really nicethat1man is just really nice
2006 RELAY-2
2007 ION-2 Sedan
Default Re: 07 ion water pump replacement... timing chain also?
Originally Posted by pierrot View Post
I see. I will try to be as clear as I can possibly be. A bearing, whether it be the water pump's impeller bearing or a wheel bearing, will make a "humming" noise continuously. Over time the intensity of the hum increases. It will not subside - ever.
Water pumps in and of themselves do not rattle. A chain, whether a balance shaft chain (which drives an ECOTEC 2.2L engine's water pump) or timing chain, which is losing tension will rattle. In order for you to assist yourself in finding the source of the noise I would recommend that you utilize,
1) a mechanic's stethoscope http://www.lislecorp.com/divisions/p...s/?product=325 (available in auto parts stores or on-line), or
2) a long shanked screwdriver (flat or four point, it doesn't matter) of about two feet in length (place your ear near to the handle while resting the tip against a part of the engine and listen for sounds traveling through it).
I have both items, but in this case I definitely prefer using the stethoscope. The sound, or sounds, heard will be much clearer.
It is true that there is a valve lash "adjustment" on these engines and so a rattling may emanate from the cylinder head. However, adjustments in this area are made by replacing parts and not actually making a direct mechanical "adjustment" on to any part. BTW, where do you reside? What are the average daytime temps at this time of year? Cold weather can have a negative impact on the oiling of the upper valve train and result in excessive noise there until the engine is adequately warmed up.
It seems to me that the noise problem relates to one of two things (one of which can have two causes):
1) a loose chain
a) caused by a weak tensioner unable to maintain adequate pressure against the tensioner guide and/or
b) a different worn chain guide, or guides;
2) valve lash adjustment.
Yes, the sound goes away after the car warms up. I reside in the Houston area of Texas. You mention one of the possibilities being the chain.. if so the sound wouldn't go away after a while, right? So it's something else you think? I got a stethoscope. Gotta go pick it up from my P.O. box
As for the "rattle", could it be the water pump if the sound goes away after the car warms up? Its more of a sound of something rubbing up against something else and it gets slightly more intense when I turn the wheel or go over speed bumps.. or the slightest bumps in roads
Add to that1man's Reputation
Rate the quality of this post and help that1man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
that1man is offline   Reply With Quote
Old 04-09-2018, 12:43 PM   #62
that1man
2006 RELAY-2
2007 ION-2 Sedan
Where are places one should put the touching end of the stethoscope? There is something I touched with the mechanical attachment and there was a rattle that I could not here without the stethoscope. Not sure if it's normal or has anything to do with whatever issues I'm having though. When I get a chance I'll take a pic of what I'm talking about. Other than that, would appreciate some guidance
Old 04-09-2018, 02:02 PM   #63
pierrot
pierrot's Avatar
It is relatively common to have a timing chain rattle at start up - lasting two seconds or less - and then not occurring further until the next start up, or perhaps not occurring for several hours, or until the next morning's first start up. At this time we just don't know what's happening. (If indeed the chain rattle lasts longer than two seconds at start up then there is a serious problem which must be addressed. This type of rattle is very obvious, being heard easily without the benefit of a mechanic's stethoscope since it's quite loud.)
No. Refer to the response above. As previously stated, water pumps in and of themselves won't generate a rattling noise.
This description is inconsistent with what you've mentioned previously. You seem to be describing something related to a front end suspension noise, perhaps a wheel bearing. Is there more than one noise you're hoping to identify?
To check the water pump you can place the probe directly in contact with pump which is located at the front of the engine block extending towards the firewall. You should see a tube attached to the rear of it running beneath the exhaust manifold. To listen for chain noises you could place the probe against the timing chain cover, valve cove, or even the front of the cylinder head which are locations nearest the timing components. Otherwise, you may place the probe anywhere on the engine or other mechanical parts you wish to listen to. (It's simply a matter of using some imagination to determine where to place the probe as there is no right or wrong in this.)
310,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 09-01-2018, 02:25 PM   #64
that1man
2006 RELAY-2
2007 ION-2 Sedan
For the time being, the best and easiest advice to give to you is that you check the oil at least once every two to three weeks and change it more often than is recommended by the factory.
I have been going by this good advice as the oil doesn't last as long as it should. Keep having to add a quart every other week like a month or so after a fresh oil change
Old 05-03-2019, 04:22 PM   #65
that1man
2006 RELAY-2
2007 ION-2 Sedan
Originally Posted by rb6667 View Post
Good Advise from your mechanic. Do not drive that car. If it is the timing chain and it breaks, you will be looking at serious damage to the engine.
How many miles on that engine?
Does it matter if I'm driving or not? If it breaks while the car is idle in park is that as bad as if it breaks while driving? I would assume not. I think it just broke. as soon ass i heard somethink that sounded like a bird flew in the assembly fan i immediately turn the engine off. Literally 2 minutes before i told myself i was gonna get it fixed before it breaks and i think it happened. Was just about to start driving too smh. I hope nothing other than the chain is damaged. My strees level is through the roof right now
I turned the engine back on for about a second and a half just to see what would happen and the engine turns on but there is a vibration. Please advise. Until then I'm going too contact the mechanic that repaired my transmission
Thanks in advance
Old 05-23-2019, 07:04 AM   #66
GREENE
GREENE is on a distinguished road
The siphon and timing chain won't influence your cooling. You have to affirm whether your radiator fan is running when it ought to be. It isn't typical for it to cycle on and off oftentimes like you recently portrayed.
Add to GREENE's Reputation
Rate the quality of this post and help GREENE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GREENE is offline   Reply With Quote
2004 L300 Timing belt/Water Pump Replacement DanCan80 L-Series Tech 2 04-03-2017 05:00 PM
06 V6 Timing Belt & Water Pump Replacement Question jeepfix Vue Tech 1 04-16-2014 04:55 PM
02 Vue timing chain-water pump? FBJR Vue General 4 07-09-2012 11:26 PM
water pump or timing chain? 96SaturnSc1cp S-Series General 8 05-02-2006 08:23 PM
Timing chain / Idler pulley / water pump questions. Spazie S-Series Tech 6 11-16-2003 04:41 AM
