Old 12-09-2007, 09:29 PM   #21
GS Jon
GS Jon is on a distinguished road
Default Re: Oil Filter Location
The location isn't all that bad. Really reminds me of changing the oil filter on my W-Bodies. Only problem is the last knucklehead who did the oil change and filter screwed it on too dang tight!
That's a problem I'll never have to deal with again! First time working on anything with a newly acquired used car is always the worst, I've noticed. Some greasemonkeys are just too gung-ho about torquing things down, it seems.
Add to GS Jon's Reputation
Rate the quality of this post and help GS Jon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GS Jon is offline   Reply With Quote
Old 12-09-2007, 09:30 PM   #22
sl_don
sl_don is on a distinguished road
sl_don's Avatar
2004 VUE 3.5L
Hey at least it wasn't a Hyundai excel on those cars if the engine mounts are anything less than brand new you cant get the filter out it gets pinched between the engine and the frame before even being halfway untheaded.
last one of those i did involved lifting the engine with a fork lift to get the filter off. the oil change was a complete wast of time becaus it burned more oil than gas
If it isn't broken.........Your not trying hard enough
2002 SL first brand new car in my family since the 1981 Pontiac Phoenix (sold)
2004 Vue AWD V6 bought used (current)
Add to sl_don's Reputation
Rate the quality of this post and help sl_don reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl_don is offline   Reply With Quote
Old 12-10-2007, 08:15 PM   #23
jake00sl2
jake00sl2 is on a distinguished road
i had the same problem.. oil filter wrenches dont work.. theres no space to dick around at ALL.. i found the almighty channel locks and screwed that summ***** off.. but yea, the oil filter placement on the newer sl's were a bad idea
....saturn Sl2 With some SL1 qualities ;).....
Add to jake00sl2's Reputation
Rate the quality of this post and help jake00sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jake00sl2 is offline   Reply With Quote
Old 12-10-2007, 08:25 PM   #24
Squareback
Squareback's Avatar
2005 ION-2 Sedan
In my 5 years at the Saturn dealership I never had trouble using a filter wrench on any S-Series car.
Certified Saturn Technician
Old 12-10-2007, 09:18 PM   #25
Project84
Project84 will become famous soon enough
Project84's Avatar
2009 AURA XR
laying in one's driveway and standing under a lift are two different things my Saturn Tech friend.
John
'09 Saturn Aura XR 2.4L
Previous - '01 SL1 daily driver and '96 SL2 auto 40+mpg hypermiler.
Add to Project84's Reputation
Rate the quality of this post and help Project84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Project84 is offline   Reply With Quote
Old 12-10-2007, 09:25 PM   #26
Squareback
Squareback's Avatar
2005 ION-2 Sedan
They most certainly are. All of the oil changes I did on my '92 SC were done on my back, on ramps, in my driveway. I still had no difficulty in changing the oil filter. At least on my own car it was installed properly and no filter strap was necessary to loosen it.
Old 12-10-2007, 09:43 PM   #27
eRic 02sc2
eRic 02sc2's Avatar
Originally Posted by greensaturn View Post
Why! It took him an hour to do the oil change, and you want him to drive up on ramps, and then lift the back of the car too? That'll add another 15 minutes to the job by the time you raise and lower the car.
Like someone else said, just turn the wheel all the way to the left reach in with your left hand and a strap style filter wrence and you'll be able to do the entire job in 15 min.
my Saturn is lowered and has 4 inches of ground clearance. the oil drain plug and filter aren't coming off unless it's jacked up or on ramps
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-11-2007, 08:31 AM   #28
sl_don
sl_don's Avatar
2004 VUE 3.5L
done it both ways never had a problem and all i need to get mine off is a rag.
if you need a tool its on too tight. from underneath there is lots of room to get it.
the problem is controlling the mess. for me i loosen the bugger and let it drain into the cute little gutter and to this point all is good but then once it stops dripping i remove it and make a mess. atleast my frame wont rust there.
Old 03-08-2015, 08:56 AM   #29
OldGuy43
OldGuy43 is on a distinguished road
OldGuy43's Avatar
Once again SaturnFans and the search engine have come to my rescue. I've been hunting for this sucker for days.
Thanks y'all.
Rights are not gifts from the government!
Add to OldGuy43's Reputation
Rate the quality of this post and help OldGuy43 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OldGuy43 is offline   Reply With Quote
Old 03-08-2015, 10:30 AM   #30
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
You sure do have a knack for resurrecting ancient threads.
I generally make a "gutter" out of a piece of cardboard and lay that over the axle so that the oil coming out runs off to the side and into my catch bucket. Otherwise it gets all over the axle, CV joint, and subframe and makes a big mess. Now that 3D printers are all the rage, it would probably be trivial to print something out of plastic that you could snap on to the axle before loosening the filter that would redirect the flow to the side. I don't have my Saturn anymore so I'll leave that exercise up to the next gearhead with an IT streak. Submit that idea to Dorman and then remember me with a case of beer when you make your first million.
Best,
All governments suffer a recurring problem: Power attracts pathological personalities. It is not that power corrupts, but that it is magnetic to the corruptible. -Frank Herbert-
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 03-08-2015, 11:32 AM   #31
Bob243
Bob243 is on a distinguished road
Bob243's Avatar
1991 SL1
Is a good idea, but I believe it has been thought of and used. My S10 has a plastic gutter below the filter which drains right next to the drain plug. although the down side of them is unless you run a towel through it when you're done, oil sits in it and drips all over your driveway.
Add to Bob243's Reputation
Rate the quality of this post and help Bob243 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bob243 is offline   Reply With Quote
Old 03-08-2015, 12:36 PM   #32
OldGuy43
OldGuy43's Avatar
Best,
Well, I suppose I could just start a new thread with a question that has already been asked and answered.
Old 03-08-2015, 12:46 PM   #33
Sid
Sid will become famous soon enough
Sid's Avatar
(for the guy who posted on this thread about 8 years ago )
I couldn't loosen my filter by hand last oil change but I have an older version of this filter wrench which does the trick. Note, it grabs the filter from the end and will only loosen it, not tighten it.
http://www.sears.com/craftsman-unive...p-02820523000P
96 SW2 5MT
Add to Sid's Reputation
Rate the quality of this post and help Sid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sid is offline   Reply With Quote
Old 03-08-2015, 01:20 PM   #34
J N Winkler
J N Winkler is a jewel in the roughJ N Winkler is a jewel in the roughJ N Winkler is a jewel in the rough
Filter pliers (which Fram makes and is sold at Walmart) will also do the job. I had to use a pair of them when I changed the filter on my SL2 for the first time.
Add to J N Winkler's Reputation
Rate the quality of this post and help J N Winkler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
J N Winkler is offline   Reply With Quote
Old 03-08-2015, 01:22 PM   #35
VUEmaniac
I generally use the "cap" type that just pops on to the end of the filter and then you can just use a 3/8" ratchet to loosen/tighten the filter. When tightening, I generally spin it on by hand until it stops and then do another 1/2 turn. That's worked for me since the 70's.
Best,
Old 03-08-2015, 05:55 PM   #36
SLfun
SLfun will become famous soon enough
2006 ION Red Line
I generally make a "gutter" out of a piece of cardboard and lay that over the axle so that the oil coming out runs off to the side and into my catch bucket. Otherwise it gets all over the axle, CV joint, and SUBFRAME and makes a big mess.
Best,
Let the oil soak that sub frame, that's what keeps the pass side from rusting away, for those of us that live where there is snow, or lot's of dampness. Maybe I should change the transaxle oil more often, and let it run all over the driver's side subframe
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLfun is offline   Reply With Quote
Old 03-08-2015, 06:23 PM   #37
racinginblood
racinginblood will become famous soon enough
racinginblood's Avatar
1998 SL1
thank god for once a year oil change
Add to racinginblood's Reputation
Rate the quality of this post and help racinginblood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
racinginblood is offline   Reply With Quote
Old 03-09-2015, 09:14 PM   #38
slapshot 11
slapshot 11 has a spectacular aura aboutslapshot 11 has a spectacular aura aboutslapshot 11 has a spectacular aura about
1999 SL1
Richpin has a video that shows you how to cut and trim an old quart oil bottle into a neat little oil catcher so the oil does not run everywhere when changing the filter.
Add to slapshot 11's Reputation
Rate the quality of this post and help slapshot 11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slapshot 11 is offline   Reply With Quote
Old 03-10-2015, 01:25 AM   #39
Tiger
Tiger's Avatar
Changing filter every other oil change is making more sense to me. Buy oversized, quality oil filter. With my Fumoto valve one oil change will be a matter of opening Fumoto valve then closing it. That is what I plan to do this week.
Add to Tiger's Reputation
Old 03-10-2015, 01:58 AM   #40
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
I have no problem driving up a couple planks, chocking the rear tires and sliding under and getting some quality time with my Goldie. I got a few PSL20195 filters that I may use for 2 OCIs of between 3.5k & 5k miles. I have a magnetic drain plug so I can loosen it all the way and not make a mess. Then take some pliers to grab the plug and pull it away. How fast does the Fumato drain? It seems a faster drain would empty out more contaminents??
1999 SL2 A4 -83k miles
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Oil Filter Location - WHAT?? Pitcher S-Series General 29 09-18-2009 11:44 PM
99 sc2 oil filter location? Salsa88 S-Series Tech 5 01-17-2008 06:25 PM
oil filter location ErichPryde Vue Tech 5 11-14-2007 06:27 PM
Oil Filter Location? markcp S-Series Tech 2 05-13-2006 11:40 AM
3.5L oil filter location? Bullet Vue Tech 2 06-26-2005 11:24 AM
