Old 05-20-2019, 09:25 PM   #1
Silverblu02SL2
Silverblu02SL2 is a jewel in the roughSilverblu02SL2 is a jewel in the roughSilverblu02SL2 is a jewel in the rough
Default Evaluating AC performance in 2002 SL2
Today was the first hot day in NYC, probably got up to 89F. I drove the Saturn and for about an hour in traffic and had the AC on full blast, it felt comfortable but I was not frozen out. It seems if it gets into the 90"s it may not be good enough.
How good is the AC in a 2002 SL2? I am going to use a black light to inspect and see if there are signs of dye which indicates a leak.
1/28/2019 2002 SL2 w 62k miles
Add to Silverblu02SL2's Reputation
Rate the quality of this post and help Silverblu02SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Silverblu02SL2 is offline   Reply With Quote
Old 05-20-2019, 10:24 PM   #2
Default Re: Evaluating AC performance in 2002 SL2
^^ that's the best first step.
Dye present? DIY or a shop for repair.
Old 05-20-2019, 11:17 PM   #3
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
I can't say about an '02, but my '94 was never impressive with cooling even when new. I have had it serviced by a pro once, and then did it myself recently. It never has gotten better than "OK", not at all like other GM cars I have experienced that will get you feeling too cold. I guessing it is a smaller than usual capacity to avoid load on the engine and increase fuel economy.
Add to billr's Reputation
Old 05-21-2019, 12:08 AM   #4
Service manual charts list four temperature ranges; 70F, 80F, 90F and 100F. At highway speed (when airflow cools off the condenser coil, increasing ac cooling efficiency inside a car, outlet temps will vary between 44F-53F. In high humidity, vent temps will vary between 46F-65F. Expect higher temps when sitting in traffic (less airflow thru condenser coil and hor radiator). The cooling fan must be running to help with local traffic speeds.
Old 05-23-2019, 09:05 PM   #5
Turbo1002
Turbo1002 is on a distinguished road
My experience. On the freeway you should be seeing about 40 degrees F. Which is nice and cold. Stop and go city driving on a 90 degree day, 50 degree vent temps. Just enough to keep you from sweating.
1999 SL2 DOHC
Add to Turbo1002's Reputation
Rate the quality of this post and help Turbo1002 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Turbo1002 is offline   Reply With Quote
Old 05-24-2019, 12:26 AM   #6
Zeebins
Zeebins's Avatar
This is from a 00-01 service manual, although, the same numbers apply to all S-Series. (or at least 94+, I'm not sure if the early R-12a systems where any different.)
File Type: jpg Screen Shot 2019-05-24 at 12.18.45 AM.jpg (92.4 KB, 9 views)
File Type: png Screen Shot 2019-05-24 at 12.19.26 AM.png (36.4 KB, 8 views)
1997 SL2, 114K miles
Add to Zeebins's Reputation
Old 05-24-2019, 02:35 PM   #7
Highmile
Highmile's Avatar
any number of things can affect it's performance.. in particular order
Freon charge
coolant fan
air flow thru the radiator
expansion valve
Of course other things can as well but these are the major player I've had to deal with over the years.
A few years ago we had record heat and the a/c was not only not keeping me cool but the engine temp kept creeping up. All 4 windows down at 60mph with the heat on wide open when it's 144 degrees is no fun. Turned out the condenser was nearly completely plugged with tiny little rocks, bugs, and other debris. It's now standard practice to blow them out any time the fan or radiator is out for any reason.
Highmile
'95 SL1 685k and counting
Add to Highmile's Reputation
Old 05-24-2019, 03:54 PM   #8
? 144 degrees F ?
Were you driving in Iraq or the Great Sahara desert ?
Old 05-24-2019, 04:15 PM   #9
Upstate Saturn
Upstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really nice
Upstate Saturn's Avatar
2001 SL2
Glad you asked this question, I'm having the same issue in a 2001 SL2. I'm the original owner and I remember that it cooled better in the early days. Has the type of coolant changed over the years, and is that the cause of the issue?
2001 SL2 manual - original owner - remanufactured engine at 228k miles, December 2015
1992 SL1 - bought used in '93, totaled in '00 at 170k miles, drove it cross-country a lot!
Add to Upstate Saturn's Reputation
Rate the quality of this post and help Upstate Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Upstate Saturn is offline   Reply With Quote
Old 05-24-2019, 05:03 PM   #10
There was a recent thread discussing the Schrader valves as a frequent slow leak area causing decreasing AC performance. Because they are under dust caps, they do not show up on UV light. When testing with an AC gauge set, they are sealed by the set itself, so don't leak when testing.
could also be evaporator dirty or plugged. Some links and pics towards the bottom of this trhead
http://www.saturnfans.com/forums/sho...d.php?t=237063
Old 05-25-2019, 08:39 AM   #11
RobertGary1
1996 SC2
ITs amazing how much of a leak those plastic epa caps can hold in. If there is enough of a leak to let gas past them youíll hear a rush of gas as you remove the epa cap and free the gas itís trapped.
Common place for leak is the front seal of the compressor.
-Robert
Old 05-30-2019, 10:30 AM   #12
Highmile
Highmile's Avatar
Originally Posted by toggenburg View Post
? 144 degrees F ?
my bad... 114 degrees
Highmile
Old 05-30-2019, 10:40 AM   #13
Originally Posted by Highmile View Post
Highmile
Neat!
Old 06-02-2019, 01:13 PM   #14
Silverblu02SL2
Have not driven the car since I last used the AC. I will take it for a drive later and take some vent temp measurements.
What's the best way to clean the AC condenser and evaporator in my 02 SL2?
I do have some AC experience revamping my 85 Mercedes 300D's AC:
Took compressor, dryer, TXV out, flushed all hoses, evap and condenser, replaced compressor with a rebuilt unit, replaced TXV and dryer, pressure tested system with Argon, charged with R12 by weight (have 30 lb bottle of R12). The condenser was easy to access and clean. Evaporator not so easy, removing it was out of the question (probably 20 hour job) so I used evap foam spray clean via removal of blower, followed spraying with a water hose and also a WaterPik water flosser.
Old 06-02-2019, 01:53 PM   #15
Random youtube videos reveals how commercial hvac techs clean residential hvac units. Techs spray a foam cleaner on stationary condenser coils after removing covers to expose both sides. After foaming a garden hose rinse removes dirt buildup. I would search for hvac foam cleaners safe for aluminum. Some are more caustic than others. Evaporator coils are more difficult to clean and less accessible. A member here posted snapshots of his evaporator coil after removing the blower motor, inserting a cellphone to snap views of leaves collecting around the interior. Vacuuming and air pressure removed a relatively clean evap coil.
2002 SL2 Maintenance/Performance Log bachands S-Series General 118 04-21-2018 03:03 PM
Evaluating a compression test Dalamar S-Series Tech 13 09-18-2011 12:25 AM
Report: Penske Automotive Group Evaluating Renault Samsung SM3 as Possible New Saturn Charlie General Saturn Discussion 24 08-05-2009 09:46 AM
Evaluating a Power Steering Pump xserver S-Series Tech 1 10-13-2008 03:53 PM
2002 SL2 Performance parts HPINitro S-Series Tech 7 03-12-2003 10:00 PM
