Old 05-19-2019, 11:25 PM   #1
FreedomSoftware
FreedomSoftware will become famous soon enough
2008 Astra XR
Default LED that work
So a while back i bought some LED headlight bulbs for my car. They worked for a while but would always end up burning out after 6 months or so. The company I got them from had a lifetime warranty but I got tired of them burning out so I went back to regular halogen bulbs. Does anyone have an suggestions for some decent LED lights that are plug and play? I dont know a lot about wiring, but it wouldnt be issue if I absolutely had to. Just want something that would be easy to install.
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-Thule Roof Rack (and wind fairing)
-1.25" Lowered
-Windows Tint all around
-JVC Head unit
-Dual 12" Subs
Add to FreedomSoftware's Reputation
Rate the quality of this post and help FreedomSoftware reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FreedomSoftware is offline   Reply With Quote
Old 05-20-2019, 12:10 PM   #2
Default Re: LED that work
Not familiar with Astras so I would ask a few questions about your lighting before proceeding with light mods.
Are your daytime running lights using low beam, high beam or turn signals?
Presuming you're asking about upgrading low beams depends on whether or not they're used as DRLs. If low beams aren't used as DRLs, the next question is are they reflector or projector light housings? Reflectors are larger diameter than the smaller diameter projectors. You can see the lamps in reflectors but cannot see lamps in projectors. Each light housing has its pros and cons with adapting led or hid lamps. If low beams are used as DRLs, this may complicate using other lamps than stock halogens.
As you found out, led lights aren't guaranteed to last, especially if they're prone to overheating. It's buyer beware when modifying from halogen to led or hid lighting.
Old 05-22-2019, 08:16 PM   #3
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
You would be better off getting a quality HID canbus kit for roughly the same price and you will have better output. Been using HID in my astra for over 6 years now with no issues. Finally burnt out a ballast this year!
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Add to nicolas_p's Reputation
Old 05-23-2019, 08:20 PM   #4
Astra08
Astra08 is on a distinguished road
Astra08's Avatar
2008 Astra XR
LED's are great for vehicles designed for them optics-wise, or in a vehicle where you replace the entire assembly with a complete unit.
I did that with both my Jeep Wrangler and two of my Harley's (coincidentally uses the same 7" size bulb and pigtail) but kept with HID's on my XR. No issues.
Add to Astra08's Reputation
Rate the quality of this post and help Astra08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-23-2019, 08:22 PM   #5
FreedomSoftware
2008 Astra XR
Any specific brand? 6 years is an insane amount of time before burnout.
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-1.25" Lowered
-JVC Head unit
-Dual 12" Subs
Old 06-23-2019, 11:24 PM   #6
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
Sorry about the late reply, just moved into a new place and haven't been on my computer since.
I used the hylux canbus with Morimoto bulbs
https://www.theretrofitsource.com/am...anbus-35w.html
2001 SL2 - power mirror and locks don't work but power windows work vikasevan S-Series Tech 6 03-31-2016 05:55 PM
Air Bag Light On. Then Horn Not Work. Then Cruise Not Work jrw1621 Vue General 4 02-05-2015 10:54 AM
Will 275/70/18s work? CGTIII Outlook General 0 04-29-2013 03:42 AM
98 SL2 wont start, horn wont work and key fob wont work blade1981m S-Series Tech 4 08-29-2010 11:07 PM
To work...Or not to work...At a Saturn Dealership? koasterking General Saturn Discussion 11 08-09-2007 08:12 PM
