Old 01-24-2018, 11:43 PM   #1
Highmile
Highmile's Avatar
Default Sun Visor question
has anyone swapped another sunvisor into a first gen SL?
unfortunately my drivers side broke tonight on the way home.
anyone have a decent one they'd part with?
Highmile
'95 SL1 649k and counting
Add to Highmile's Reputation
Old 01-25-2018, 09:10 AM   #2
trottida
trottida's Avatar
Default Re: Sun Visor question
I recently saw someone who was looking to install a 2003 to 2007 Cadillac CTS sun-visor that looked like the mount was exactly like the S Series. I hadn't heard if it worked out for the poster though as far as the clip goes. It was less expensive than the S Series sun visors on eBay and an upgrade as the comes with lighting. Here's what the mount looks like.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 01-25-2018, 11:08 AM   #3
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Pm Sent
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-16-2018, 02:30 AM   #4
mnementh
mnementh will become famous soon enough
mnementh's Avatar
2001 L-Series 2.2L Sedan
I can confirm that the 2003-2007 Cadillac CTS sun visors fit my wife's 2000 SL1 nicely and look good, but you want to do this swap as part of recovering the headliner, as they are about 2" longer (Yes, they do clear the rear-view mirror just fine) and you have to move the pivot clips. This will leave the holes from the original pivot clips unfilled.
I'll update here with the details of my mod and some pics later when the headliner is finished.
In case I don't manage any time soon, here are the bullet points; I swear, I must've crawled through a hundred CTSes in the boneyard to gather this information:
1) I can only confirm the fitment of the vinyl lined visors from 2003-2007 Cadillac CTS as seen in the photo by trottida above. Older/Newer are covered in fabric and newer models often have a goofy "sunvisor on top of a sunvisor" arrangement. The fabric ones all look pretty nasty at this age, and many have started to rot like the SL1 visors chronically do. The vinyl cleans up pretty well, though, and even in the Texas sun they don't seem to get too yellowed.
2) There are some models that have a built-in universal garage door opener; these must be inspected carefully as they often have holes/voids where the skin has pulled away around the cutout for the opener. Remember too that they will need to have a 3rd power wire installed for the opener.
3) You also need to get the screws and the pivot clips from the donor vehicle; the base is made for these larger headed screws. But wait, you need two DRIVER'S SIDE clips, as the passenger side clip is different with a huge hole and a steel sleeve molded inside, with an m8 x 40mm machine thread bolt going through it. Yes, I saw this on multiple vehicles, so it is designed this way.
4) You need to pull the headliner down on the donor vehicle in the corner near where you unbolt the visor from, then reach in and skin back the wiring harness so you can get as much wire with the visor connector as possible. You can get around 3 feet if you skin as far back as you can reach; this will make it possible to route the wires out under the A-pillar plastic trim for connection later.
Cheers,
mnem
*Currently renovating my wife's 2001 SL1 that just turned 250,000 miles.*
Add to mnementh's Reputation
Rate the quality of this post and help mnementh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mnementh is offline   Reply With Quote
Old 06-16-2018, 02:34 AM   #5
Macgyver
OP needs a 1st gen visor (91-95) which is a 2 bolt mount. They're not compatible with the 96-02 visors. You'd have to drill/tap new holes which would be risky with how thin the roof is.
Add to Macgyver's Reputation
Old 06-17-2018, 12:18 AM   #6
mnementh
mnementh's Avatar
Meh.
I was responding to trottida, as his post was relevant to my own case, and turned out to be good advice, at least for me.
I can make a new thread when I have some pics to post.
I haven't had a 1st gen since my '92 became a victim of Saturn-on-Saturn violence with my brother-in-law at the wheel... It was about to turn 300k; it died much too young.
mnem
I need more ascii characters down here.
Old 06-19-2018, 01:06 PM   #7
Highmile
Highmile's Avatar
I did find visors some time ago and went with the 3 screw type that came in the later model saturns.
They are a bit bigger and overlap the indent in the headliner a bit but it's a small price to pay for having a functional sun visor when driving into the sunrise or sunset.
Highmile
'95 SL1 660k and counting
95 SC2 Sunroof Visor jgcox6 S-Series General 3 04-18-2011 03:34 PM
sun visor?? 1994Saturn S-Series Tech 1 04-03-2007 09:34 PM
Sun Visor sat96 Classifieds 8 06-25-2004 02:13 PM
Need visor Kutzy12 Classifieds 4 03-30-2004 05:53 PM
TV in visor trans4mer Mods and Performance 15 09-04-2002 09:25 PM
