Old 05-29-2018, 03:04 PM   #5461
Saturn Night
Default Re: What did you do to your S-Series today...
At 193,401, it received 4 fresh quarts of Rotella 5w-40 T6 synthetic and a Purolator PL20195 oil filter. Transmission fluid is next on the list, and a new Wix filter.
Old 05-29-2018, 06:14 PM   #5462
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
Originally Posted by OldNuc View Post
I hope that is a spare junk O2 sensor. Paint can block the O2 reference air and the fumes may contaminate the sensor as the manifold is open. Other than that looks good.
Yep, old junk from the bottom of the tool bag, thank you very much ^ .^
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Old 05-29-2018, 08:52 PM   #5463
pgagl
pgagl is on a distinguished road
Today I swapped bumpers with an extra one I found at a junkyard about two months ago. Decided to get it out of the basement and swap it with the old beat one.
I plan to sand and paint the old bumper while it's off. Sounds like a good summer project to me
Old Bumper
New Bumper (Back)
Not bad for having 180k on her
1997 Sl2 5-Speed 177k
Add to pgagl's Reputation
Rate the quality of this post and help pgagl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pgagl is offline   Reply With Quote
Old 05-30-2018, 04:34 PM   #5464
Friday, stopped at Menards and picked up a couple of bolts
http://www.saturnfans.com/forums/sho...&postcount=138
Then got home and fount the package from McMaster-Carr had already arrived They are fast!
Now they are all sitting on the table waiting for me to have time
Saturday, replaced both valve stems in the AC Schrader valves. Then added a full 12 oz can of R134a. Pressure seemed low (I didn't feel like dusting off the gauge set and hooking it up, so just used the one on a cheap refill unit for the low side).
Drove the minivan on Tuesday, AC felt a little weak so some weekend, may pull out the gauge set and split up another can of R134a between the two cars. I'll check pressure on both and see if they both need it . . . would hate to tap a can and not need the whole thing.
Old 06-03-2018, 03:39 PM   #5465
nsw
nsw is on a distinguished road
2002 SL1
Saturday, rolled over 200k so did an oil change. Checked front brakes while I was in there, pad life looks fine. Not sure where this squeak that I have is coming from..
Add to nsw's Reputation
Rate the quality of this post and help nsw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nsw is offline   Reply With Quote
Old 06-09-2018, 04:11 PM   #5466
Waiex191
Waiex191's Avatar
I programmed my key fob. Thanks Erik for the eBay link!
Also I put if a couple visor clips from the junkyard. Mine were missing.
I have a horn again. My dad gave me a new in the box horn he bought for his boat. I am going to look for a louder one.
I've got about 1000 miles since the last oil change. Still above full. The leaks and usage don't seem bad.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 06-09-2018, 04:49 PM   #5467
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Finally got around to doing the other rear door sill
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-10-2018, 01:21 AM   #5468
Nekomimi
Nekomimi's Avatar
1996 SL1
I swear if this oil pan still leaks, ill be a little upset.
Old 06-10-2018, 11:48 PM   #5469
Zeebins
Zeebins's Avatar
I did this about a week ago now but waited to post to see what using them would be like. Sanded and clear coated the headlights to try and make them look/ function better. It wasn't a huge difference when I finished so they either weren't that bad to begin with or I just didn't do that good of a job. These headlights already have so many lines (I'm not sure what else to call them) on the inside of the housing that it makes it hard to tell how clear they really are. Visibility at night is probably about the same as before but they look cleaner now, so I'll take it.
Old 06-11-2018, 03:59 PM   #5470
bumpdraft
bumpdraft's Avatar
1998 SW2
POR15 painted a set of used, almost newly-rebuilt calipers.
They will require a finish coat. What color should old Saturn owners paint their calipers?
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 06-12-2018, 02:26 PM   #5471
ErikTande
ErikTande will become famous soon enough
ErikTande's Avatar
I made the back of my wagon into a big cooler for lunchtime naps. I have newborn and need to sneak in sleep whenever I can, even at work.
I used reflectix and then black construction paper on the outside to make it a little more stealthy. I'm sure adding the paper makes the reflectix a little less efficient, but I don't care. It's still WAY cooler in the car. I need to make one more for the very back window and make a couple for the 2 front windows as well. The windshield is blacked out with a regular sunshade.
I can run the AC for 10-15 mins, get it nice and cool and nap for a good hour before it starts getting too hot, even in 90 degree weather.
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 06-12-2018, 03:59 PM   #5472
Zeebins
Zeebins's Avatar
^^^^That would be really cool to combine with the "Shaggin Waggon" http://www.saturnfans.com/forums/sho...d.php?t=156776
Although with a newborn that probably makes that mod a little impractical...
Old 06-15-2018, 07:39 AM   #5473
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
Throw rug roof rack!
Ingredients:
(3) 30 x 50 throw rugs. (I keep them in my SW2 almost all the time with the back seat folded down)
(Lots of) free twine from hardware superstore.
Directions:
Lay one rubber backing side down on your roof and place the other 2 rolled up nappy side out like yodels to create the rails.
Using the plastic twine supplied free of charge at The Home Depot, tie your cargo using the dental floss method. (The dental floss method is the theory that the more times you wind the string around an object, the greater its ability to grab hold.)
Both fore and aft lengths of plastic twine get fed through the openings of the rear doors (while doors are open and not through the window frames)
This worked surprisingly well with the 2 2x6x12 ans 1 2x6x8 of pressure treated lumber.
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 06-16-2018, 03:49 PM   #5474
Zeebins
Zeebins's Avatar
Washed the car, waxed the paint, vacuumed the floor, washed the carpets...basically a lot of cleaning.oddly, the drivers side floor mat has held up better than the passenger side. Weird but I'll take it
Old 06-17-2018, 05:00 PM   #5475
bumpdraft
bumpdraft's Avatar
1998 SW2
60 mph in a 45 residential zone. Chrysler product behind me means there are no speed laws!
Old 06-18-2018, 10:12 PM   #5476
Nekomimi
Nekomimi's Avatar
1996 SL1
Trailer hitch! Main purpose is going to be for a bike rack.
Old 06-22-2018, 11:12 AM   #5477
youstolemybeer
youstolemybeer is on a distinguished road
2001 SW2
hey, on your trailer hitch, how did you keep the muffler from hitting the hitch? I just installed a etrailer hitch and it rubs against the muffler
Add to youstolemybeer's Reputation
Rate the quality of this post and help youstolemybeer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
youstolemybeer is offline   Reply With Quote
Old 06-22-2018, 12:01 PM   #5478
Saturn Night
Use the BLACK RTV sealant with the pan, because it is steel. Use the BLUE on ONLY the water pump gasket.
This will fix your leaks.
Old 06-22-2018, 12:03 PM   #5479
Saturn Night
Full tank of EFP-90 fuel. 35.2mpg combined city/highway, over the last 1,166 miles of driving. Getting about 1,200mpg on the oil, as I only used 1 gallon
Old 06-24-2018, 11:15 AM   #5480
ratwhisperer
ratwhisperer is a jewel in the roughratwhisperer is a jewel in the roughratwhisperer is a jewel in the rough
ratwhisperer's Avatar
1997 SL1
New plugs, wires, new O2 sensor, changed the oil, cleaned some things up. Going to go give her a wash here in a bit and a new air filter. Maintenance makes for a happy Cinnamon
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
1994 SL2 - Nelly Belle
Current:
1997 SL1 - Cinnamon - 285K
1996 SL2 - Blanca - 36K
Add to ratwhisperer's Reputation
Rate the quality of this post and help ratwhisperer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ratwhisperer is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
