Old 06-17-2018, 09:56 PM   #21
Default Re: Cleaning ignition coil pack?
2 coil packs sit on top of the ICM, the bolts pass through the coil to secure the assembly to the block. JY's often will charge you for 1 item if you leave the coil packs on the ICM...3 for the price of 1
1st pic is just the ICM, 2nd pic is a coil pack.
Old 06-17-2018, 11:16 PM   #22
JerryHughes
JerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of light
JerryHughes's Avatar
1997 SL
Oh, sounds good. Can't beat that price then.
Add to JerryHughes's Reputation
Rate the quality of this post and help JerryHughes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JerryHughes is offline   Reply With Quote
Old 06-17-2018, 11:46 PM   #23
JerryHughes
1997 SL
Just checked my local pick and pull and their price on a coil pack (I assume the whole assembly) is just over $50. Their sale days give 40% off that. A good deal.
Old 06-18-2018, 08:15 AM   #24
Yes, they sell the entire assembly, 2 coils and the ICM as the coil pack. That is $30 plus tax and thy usually have a 30 day or longer exchange so be ready to swap it in immediately.
Old 06-18-2018, 11:18 AM   #25
JerryHughes
1997 SL
Our local pick and pull sale days (which are full of people and you wait to check out because of all the people in line) are really popular. Probably in another month or so. I can live with this mild car hesitation until then. Hope I find a good replacement. I'll update if or when "successful". I've noticed that I can't go on our JY lots and find a lot of Saturns, like I used to! Becoming a thing of the past.
Old 06-19-2018, 11:33 PM   #26
JerryHughes
1997 SL
Just in case---at the Junk Yard. I could use years 96 through 02 coil pack in my 97??? Or do I have to stick with 96 through 99? Thank you!
Old 06-20-2018, 12:23 AM   #27
JerryHughes
1997 SL
Gee, at this site---
https://www.cheapestgmparts.com/oem-...EtOWwtbDQtZ2Fz
I've found that the part number, Ignition Module - GM (19178836) also fits these Saturns----------------
THIS PART ALSO FITS
Make Model Year Body & Trim Engine & Transmission
Saturn SC1 2002 Base 1.9L L4 - Gas
Saturn SC1 2001 Base 1.9L L4 - Gas
Saturn SC1 2000 Base 1.9L L4 - Gas
Saturn SC1 1999 Base 1.9L L4 - Gas
Saturn SC2 2002 Base 1.9L L4 - Gas
Saturn SC2 2001 Base 1.9L L4 - Gas
Saturn SC2 2000 Base 1.9L L4 - Gas
Saturn SC2 1999 Base 1.9L L4 - Gas
Saturn SL 2002 Base 1.9L L4 - Gas
Saturn SL 2001 Base 1.9L L4 - Gas
Saturn SL 2000 Base 1.9L L4 - Gas
Saturn SL 1999 Base 1.9L L4 - Gas
Saturn SL1 2002 Base 1.9L L4 - Gas
Saturn SL1 2001 Base 1.9L L4 - Gas
Saturn SL1 2000 Base 1.9L L4 - Gas
Saturn SL2 2002 Base 1.9L L4 - Gas
Saturn SL2 2001 Base 1.9L L4 - Gas
Saturn SL2 2000 Base 1.9L L4 - Gas
Saturn SW2 2001 Base 1.9L L4 - Gas
Saturn SW2 2000 Base 1.9L L4 - Gas
(Don't know why the 98 SL is not listed but it also fits that year.)
Old 06-20-2018, 12:24 AM   #28
'96-'02 will work but not only are '00-'02's more unreliable...they're harder to remove from the car. You'll see when you get there, unless someone else posts a picture of the stupidity.
Old 06-20-2018, 12:26 AM   #29
JerryHughes
1997 SL
Okay, then I think I'll just stick to the 96-99's. Thanks for the tip!
Old 06-20-2018, 06:03 PM   #30
JerryHughes
1997 SL
Okay----since I ROYALLY SCHMUCKED UP my coil packs years ago by putting dielectric grease on all surfaces, plates and all, I thought that, what the heck---why not try to simply clean everything to see if the coil pack is good? So, I did that this a.m. and so far, the car's running like it's only half its age! Worked wonders with the air cond. on or off. I didn't drive all that far but the car got good and hot and all's good. Will really test it over the next few days. The pics are of my "lard coated" coil pack, before cleaning. They cleaned up easily and well. (They should have, with all the protection they had on them) The connecting bolts, especially one, had oxidation on them and my circular wire brush that I use in my drill, shined them right up. If I don't repost on this, all went well and the car is running like a top. Thanks to all of you for your help and input! SATURN FANS ROCK!
cleaning coil pack what's the best way mytimeflies S-Series General 9 10-02-2007 11:39 PM
Shorted ignition coil pack??!? Jim Dunlop S-Series Tech 12 08-16-2007 08:34 AM
ignition coil pack ? clearnet_tw S-Series Tech 3 05-03-2006 06:11 PM
Coil Pack and Ignition Module Cleaning Questions mainedvd S-Series Tech 4 09-11-2005 03:11 PM
Coil pack cleaning poorboy S-Series Tech 4 02-17-2005 03:16 PM
