Old 06-09-2018, 10:57 AM   #1
beaverplt
beaverplt is a jewel in the roughbeaverplt is a jewel in the roughbeaverplt is a jewel in the roughbeaverplt is a jewel in the rough
2001 SW2
Default Headlight question
HI all, I have a conundrum with the headlights on my 01 SL. My low beam lights project farther than my high beams. Of course, with the headlights placed a bit farther inside than most cars, oncoming traffic flash their lights at me frequently thinking I'm driving at them with my high beams on. Has anyone else run into this?
Add to beaverplt's Reputation
Rate the quality of this post and help beaverplt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
beaverplt is offline   Reply With Quote
Old 06-09-2018, 02:54 PM   #2
Commeatus
Commeatus is on a distinguished road
1998 SW2
Default Re: Headlight question
I've seen the wrong bulbs installed before, causing the aim to be off.
the frame for the headlight housing can sometimes work itself loose, too, so having a shop aim your lights might be elucidating in either case.
Add to Commeatus's Reputation
Rate the quality of this post and help Commeatus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Commeatus is offline   Reply With Quote
Old 06-09-2018, 09:11 PM   #3
Or...aim your headlights yourself. Easy to do and far far cheaper. Especially since all the shops I know of would keep the car 1-2hrs, charge you that labor time and it'd come out untouched for that kind of job.
Old 06-10-2018, 04:57 PM   #4
^^^ +1
http://www.saturnfans.com/forums/sho...d.php?t=160907
Probably your headlights are aimed too high. I actually put in a high-beam bulb in my low spot but aimed low, and I never get flashed.
The high beam bulbs can't be accidentally put in to the low spot, you need to modify the bulbs to do this - they have extra slots to prevent this.
Old 06-16-2018, 10:14 AM   #5
beaverplt
2001 SW2
Thanks for the answers. Never thought of the high beam bulb idea. I've got some extra bulbs to "doctor". I'll give it a try.
Old 06-18-2018, 12:49 PM   #6
If you do this, be sure to test it out on a wall first.
I think the coupes have a sharp cut-off on the low-beams to prevent blinding other drivers, that the sedans and wagons do not have.
Old 06-18-2018, 04:41 PM   #7
bumpdraft
bumpdraft's Avatar
1998 SW2
The coupes seem to shine up out the side
I think the coupes have a sharp cut-off on the low-beams....
That would be an aftermarket modification of closing a pair of medium pizza trays in the hood. Be sure the lip of the pans are towards the ground.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
question about headlight mod jessie1992 Ion Mods 5 06-30-2012 07:32 PM
Headlight question simkid5614 S-Series Mods 6 08-24-2011 01:00 AM
another headlight question, I know I know, I'm sorry camzshaft S-Series General 5 03-09-2011 12:54 PM
Headlight Question weatherman0507 Ion Tech 1 11-17-2008 12:48 PM
headlight question 99GreenySC2 S-Series Mods 3 01-01-2008 05:53 PM
