Old 06-15-2018, 07:34 PM   #21
JerryHughes
JerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of light
JerryHughes's Avatar
1997 SL
Default Re: Dielectric grease on plugs?
Okay---first time I pulled this set of wires off my plugs and like the last time, I couldn't seat the wires back on the new plugs well enough. So, I cut about 1/4" of rubber at the end of the wires off (nice clean cut with a single edge razor blade) and they seated well on the wires. I must be pulling too hard when I remove the wires in the first place, I guess.
Add to JerryHughes's Reputation
Rate the quality of this post and help JerryHughes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JerryHughes is offline   Reply With Quote
Old 06-20-2018, 12:52 PM   #22
saturnsctwo
my boots would get a little stuck if not removed in a while, but some gentle twisting & turning would get them off. I never used any grease in there.
Add to saturnsctwo's Reputation
Rate the quality of this post and help saturnsctwo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-20-2018, 12:57 PM   #23
JerryHughes
1997 SL
Yup, I've moved away from grease on my plug bodies to only grease on the end terminals of the plugs.
Silicon Dielectric Grease BobbyP Vue Tech 19 11-26-2008 07:17 PM
white lithium grease can be used as brake caliper grease? microsat S-Series General 9 09-18-2007 03:19 PM
Use of dielectric grease PeteB S-Series Tech 9 09-22-2005 10:32 PM
Plug wire & dielectric grease questions RadioRon S-Series General 3 09-15-2005 02:57 AM
dielectric grease?... LI 350 Miscellaneous Tech 3 09-15-2001 05:54 AM
