Old 05-05-2018, 08:22 PM   #321
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
1996 SC2
1999 SC2
Default Re: 96 SC2 bringing it back to life (slowly)
With the AC on and in gear we have had a ruff idle. I cleaned EGR valve did not help I blocked off EGR.
That did not help. I thought I would go back to the basics.
I did a compression check.
1: 155 psi
2: 150 psi
3: 155 psi
4: 155 psi
I added oil and did the check again.
1: 190 psi
2: 185 psi
3: 185 psi
4: 185 psi
It looks like the compression rings are not seated.
The car is not using any oil at all.
Whatís the best way to get the rings to seat?
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is offline   Reply With Quote
Old 05-05-2018, 08:29 PM   #322
Drive it as they will seal when it is under load. Most likely the previous owner used a cheap oil and you have excessive wear, there is no way to reseat the rings other than running. Comet Cleanser down the intake is not recommended either.
Old 05-05-2018, 08:50 PM   #323
Mark_b
1996 SC2
1999 SC2
This is the motor I rebuilt. Maybe I switched to mobile one oil to soon.
My son Is a very conservative driver I am not sure where that comes from.
I took it out after these readings and flipped the performance switch on.
I did a few red line runs maybe 6 or 7 maybe that will help seat the rings.
Old 05-07-2018, 09:35 AM   #324
Mark_b
1996 SC2
1999 SC2
I switched it back to dino oil 10-30. I took it out on Sunday and did about 15 runs from 30 mph to 70 mpg. I floored it to get to 70. I then let my foot off the gas and wet down to 30 mph.
Hopefully this will help seat the compression rings. It ran very strong and got 70 pretty fast. It does not run like it is low on compression.
Old 05-07-2018, 10:33 AM   #325
You probably had dry rings and there is nothing wrong. A high quality synthetic stays in the upper cylinder much better than mineral based oil, any mineral based oil.
Old 05-10-2018, 07:32 PM   #326
Mark_b
1996 SC2
1999 SC2
My rebuilt valve body from Central Valve bodies came in today.
Hope to get it put in on Sunday.
Old 05-20-2018, 08:20 PM   #327
Mark_b
1996 SC2
1999 SC2
Ok I really like VXDIAG Nano Tech2Win. I now know my VIN of the replacement PCM
1G8ZH1275TZ387557
I tried to do a crank angle sensor relearn. It would not do it because cylinder two had a miss.
I could then go to a graph to see the miss in real time.
I went and tested the air idle control. I was able to adjust the idle up and down 500 rpms no problem.
I took my other sonís 99 SC2 injectors and put them in the 96. Well that did it no more miss on the graph.
I did the Crank relearn the first try. Took it out for a test drive it ran great. The ODBII instant MPG on a 20 mile trip showed 29 MPG instead of the normal 24 mpg it has been getting.
I cleared the adaptive on the trans and did the relearn. No codes at all now.
My son drove it today and no codes it running great.
I went to a upull it today and got a set of injectors while I was there I pulled a cruise control module.
I put that in my sonís 96 and now the cruise control works.
It is so nice to finally find the issue for the codes for this car.
Just one afternoon with the Tech2Win I was able to fix this issue.
The graph would show the miss even if you could not feel it and it was not bad enough to pop a code. This was so useful.
Old 05-21-2018, 08:47 AM   #328
There have been lots of hard to detect and/or understand with the well aged injectors in these older GM/Saturn cars. The recommendation is to just up and replace them with the recommended new or refurbished Bosch injectors. May of the odd issues seen on here are caused by these aged injectors. Without what you are using it is impossible to demonstrate or prove the problem is injector caused so convincing someone to drop 80-100$ for a new set which may or may not solve problem is a tough sell. It is also a tough sell to suggest someone go out and spend 100-400$ for the diagnostic hardware and software to perform these diagnosis as there is not a lot of decent documentation as to how to use it.
When the ignition system, fuel delivery, exhaust system integrity, engine compression demonstrated adequate, and the problem persists then it is highly likely to be injectors.
It does make a difference exactly which Bosch injector number you buy.
You have done an excellent job bringing these cars back from a candidate for the junk yard.
Old 05-21-2018, 09:24 AM   #329
Mark_b
1996 SC2
1999 SC2
Thanks, and thanks for your help along the way! Thanks to others here that helped and the great search feature so useful.
The VXDIAG VCX Nano was $118.74 shipped so worth it.
I have the GDS2 (this is for newer cars) software running in a virtual machine to test on my 2018 Chevy Volt. I will be trying it out soon. The virtual machine comes on the DVD with the tool. It runs on 64-bit machines.
It is very cool to be able to use the same tool for 96 SC2 and a 2018 Volt.
You do use different software.
I would be glad to post a couple screen shots of what I used to see the miss. It was no hard. There is so much other stuff in that software that I need to read up on.
The smile on my sons face his first trip with no codes was great.
Things left to do on this one. I have a heat shield vibrating just above idle. The reverse still has a delay and engages harder when warm. The second valve body did not help. They suggested I tighten the input nut on this one also. It needs painted.
I canít wait until the next gas tank to see what MPG we will be getting.
Old 05-21-2018, 09:32 AM   #330
Awesome progress, thanks for the info on the VXDIAG Nano Tech2Win.
I may pull the trigger in a couple of months. Last year, was gonna pay a local dealer $50 to program my '02 key fob (could have driven out of town and had it done for $35, but time was short). Local dealer checked and said the fob was not working, no signal. I checked myself at the FLAPS and their RF checker picked up a signal. Had been wanting a working fob for a while so was contemplating going back and dropping the money, but this tool is not that much more.
Old 05-22-2018, 09:46 PM   #331
Mark_b
1996 SC2
1999 SC2
I am very happy to say my son has put on a couple hundred miles on his car since the injector/Crank angle relearn.
No codes at all it has a great idle.
His round trip to school is about 40 miles so the miles add up quick.
I took his car to harbor freight to pick up a new floor jack I have been wanting. It is a low profile extended reach that will work great on the Saturns.
I also will lift 23 ĺĒ inches high and Minimum height is 2-5/8".
That is great for my new tall jack stands.
It is on close out for $99.97 sweet deal for a nice jack.
They are replacing it with a very nice Daytona floor jack but that jack cost $179 on sale.
https://www.harborfreight.com/2-ton-...ump-62310.html
Old 05-28-2018, 09:51 AM   #332
Mark_b
1996 SC2
1999 SC2
Still no check engine light. Code free after two tanks of gas. My son got 27.4 MPG last tank this is better than the 24MPG he was getting.
The reverse slam was getting worse. Yesterday I tightened the input and installed a new output nut I used 3M TL71 SCOTCH-WELD Threadlocker on the input nut.
I changed the trans fluid.
It is shifting supper smooth now. Reverse is just like forward with hot or cold trans fluid.
Old 05-28-2018, 10:12 AM   #333
That is good news as swapping transmissions is a PITA.
Old 06-13-2018, 01:28 PM   #334
Mark_b
1996 SC2
1999 SC2
We had the windows tinted for his birthday. The guy that tinted it said that car runs pretty darn good for a 22-year-old car.
Old 06-14-2018, 02:54 PM   #335
Nice. tint makes a huge difference when you get in the car on a sunny day. Also makes the car look cooler, as well as feel cooler.
Re-doing the PO's DIY job is on my list of things to do. It's super dark, has a purplish tint from the inside, everything is blurry looking out, and bubbled in many places.
Old 06-28-2018, 10:05 AM   #336
Mark_b
1996 SC2
1999 SC2
He loves the tinted windows.
The car now has over 4,000 miles on the rebuilt motor.
It is using no oil and has no drips. Last tank was 27 mpg with AC on always. That is our best MPG so far but it does not get a lot HWY driving.
It is very hot here right now so AC is a must have.
2004 Saturn Ion 2 QC 2.2 manual - revs slowly, returns slowly to idle chetterhead Ion Tech 14 09-22-2012 10:43 PM
Bringing the old gal back to life Hjoken S-Series Tech 21 02-24-2012 11:45 AM
Could Magnas Unique Business Model Lure Penske into Bringing the Astra Back to Lif wifeofcore General Saturn Discussion 14 06-17-2009 11:46 PM
Bringing 94 SL1 back to life - been sitting for 3 1/2 years Spazie S-Series General 19 01-02-2008 01:19 PM
bringing a $400 SC2 back to life geartooth94 S-Series Tech 9 01-12-2005 08:31 AM
