Old 09-12-2012, 01:19 PM   #1
johnyrrr
johnyrrr is on a distinguished road
1997 SW2
Default trans fault p0733 not shifting 3rd gear
I have followed the readings ive read on here to my sisters SW1 automatic with 136k on it, from others posts but its not working. I replaced fluid/filter, Turbine speed sensor, coolant temp sensor, trans temp sensor. It goes into reverse with out slamming. Ive checked the connection at the top of the trans and all sensors read 5.0-5.6 ohms. I can clear the fault codes and p0733 keeps coming rt back.
The car shifts hard sometimes into second. It goes through the gears fine and when its time to shift into 3rd sometimes it just misses and revs and totally lets go of any gear. if you coast back down to like 10 mph you can try again but usually it will miss 3rd gear. I have tried when it misses 3rd gear to put it in low gear manually and hold the rpms aroud 3500-4000 rpm for a few seconds and then put it back into D and it will go into 3rd and everything is just fine then. It then drives around flawless once its up to speed and seams like it could cruise the highway forever without trouble. When slowing down for a stop sign it will downshift all on its own a little early.Sometimes when coasting down to low speed it seems to hold onto OD for too long.
What do you guys think, Valvebody? Its like the car isnt getting the signal when to upshift and when to downshift. I really had high hopes the Vehicle speed sensor was going to be the trick . Im at a loss and she is broke. What next???
Add to johnyrrr's Reputation
Rate the quality of this post and help johnyrrr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnyrrr is offline   Reply With Quote
Old 09-12-2012, 02:04 PM   #2
Chazberry
Chazberry's Avatar
Default Re: trans fault p0733 not shifting 3rd gear
See if these diagnostics give you any ideas . . .
http://www.saturnfans.com/forums/att...2&d=1293676806
http://www.saturnfans.com/forums/att...1&d=1293675948
Add to Chazberry's Reputation
Chazberry is online now   Reply With Quote
code p0733 incorrect 3rd gear ratio edmonpierre S-Series Tech 24 02-09-2015 06:45 PM
P0733 Gear 3 Incorrect ratio code cybrsk8r S-Series Tech 3 12-20-2011 06:19 AM
P0733 gear 3 incorrect ratio - question Anjey S-Series Tech 0 07-23-2011 01:52 PM
P0733 3rd Gear Missed Shift snoman70 S-Series Tech 1 06-11-2011 11:46 AM
93sc2 trans not shifting into 4th gear joe's95sc1 S-Series Tech 1 09-15-2005 12:00 AM
