Old 10-26-2016, 11:53 PM   #1
Scoot1988
Scoot1988 is on a distinguished road
Default Changed wheel bearing, new sound/issue
Hey guys,
I changed a front wheel bearing. I pulled the spindle off and had a shop press out the bearing and put a new hub/bearing in. I put it back on the car, and now there is a new rumble/gurgling noise when applying load until about 30mph, my mpg and power is affected. I have a manual 95 SC1. Any ideas what this might be? When I tightened down the axle nut on the front passenger side, the driver side wheel was on the ground. I tightened too much and cranked the engine once , that wouldn't be the cause of the new noise, right? I lowered the passenger side and tightened further until and guessed at about what torque I was at. I couldn't locate my torque wrench, so I know it's not at the 148 ft/lb, but it can't be far off. I'll borrow a friends torque wrench and put it at the correct torque.
Scoot1988 is offline   Reply With Quote
Old 10-27-2016, 12:31 AM   #2
Default Re: Changed wheel bearing, new sound/issue
Originally Posted by Scoot1988 View Post
Hey guys,
New nut and washer and proper torque. Wheel must be rotated while torquing which requires someone to step on brake when tightening, this torquing must be done in stages to obtain proper bearing preload. If you are missing some power and a rumbling sound there is a failed bearing somewhere and that could be wheel bearing or either CV joint.
Old 10-27-2016, 12:31 AM   #3
If the knuckle came off the car the alignment is fubar and needs to be fixed.
Old 10-27-2016, 05:27 PM   #4
Scoot1988
Is it too late to do this, or did I Jack up the new bearing?
Old 10-27-2016, 06:19 PM   #5
Will cost almost nothing to try. You might luck out, it does happen every so often.
Tags
new noise, rumble, wheel bearing
Possible Wheel Bearing Issue? thesnowdrifter S-Series Tech 1 04-10-2010 02:28 AM
03 VUE - wheel bearing issue? skijay Vue General 12 09-30-2008 10:23 PM
Changed my wheel bearing/hub... spencerb Vue Tech 28 09-15-2006 09:54 AM
Changed wheel offset and bearing issues. shaung S-Series Tech 0 05-09-2005 10:47 AM
Wheel bearing failure sound skijay Vue General 10 06-03-2004 09:48 PM
