Old 10-12-2009, 04:07 PM   #1
rwpurdy
rwpurdy is on a distinguished road
Default Broken Drive Shaft???
Just curious, has anyone on here had a passenger side drive shaft break? Not the CV joint, the shaft itself right between the CV joints.
I loaned my 2002 SL2 5 speed (130,000 miles) to my (responsible) 16 year old, because his '96 SL1, Auto (196, 000 miles) had a flat tire and his girl friend was waiting. Not 5 minutes after he left, he called and said the car wouldn't move. Now, he is not the most experienced with a 5-speed, and he jerks it occasionally. But, even with massive jerking, I can't see how the shaft could have broken. It's OEM solid steel (or cast metal of some kind), and a half inch thick. At the point it broke, it was a narrower section of the shaft, with some sort of balancer/rubber sleeve thing clamped to the shaft. It looked a little rusty under the sleeve. The replacement did not have the balancer thing, and was the same diameter end to end.
After replacing the shaft, everything works as well as ever, so it does not look like anything else was damaged. What do you think, defective casting, or abusive driver?
rwpurdy is offline   Reply With Quote
Old 10-12-2009, 04:39 PM   #2
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
Default Re: Broken Drive Shaft???
They break all the time when 16 year-olds hit curbs at 60 mph! I have a teen driver too; I know what they are do.
-Robert
Old 10-12-2009, 06:08 PM   #3
Spaz
Spaz will become famous soon enoughSpaz will become famous soon enough
Spaz's Avatar
This link may give you some answers. http://www.saturnfans.com/forums/sho...t=axle+snapped
Spaz is offline   Reply With Quote
Old 10-12-2009, 06:41 PM   #4
fritoboy
fritoboy is on a distinguished road
I have been a teen driver and have raised a teen driver, you will never know exactly what happened. That said, my 98 sl2 broke the same axle in the same spot while I was driving. It had 230,000 miles at the time, cheap easy fix.
fritoboy is offline   Reply With Quote
Tags
5 speed, cv joint, driveshaft
Repeatedly broken half shaft pmcnamara S-Series General 23 12-06-2016 10:40 PM
Drive shaft removal. MarkJenks Vue Tech 3 05-15-2008 04:17 PM
Help with broken idler pulley-stub shaft mabu_888 S-Series Tech 12 10-23-2007 12:02 PM
Front Right Drive Shaft heathen Vue Tech 2 06-14-2007 10:54 PM
RL Drive Shaft Vibes RedLineRebel Vue Red Line 1 11-09-2004 10:03 PM
