Old 06-18-2009, 09:37 PM   #1
cubcadet149
cubcadet149 is on a distinguished road
Default 1995 SL2 Front End Vibration
I have a 95 SL2 (Auto Tranny) that has a bad vibration in the front end. It seems to be in the drivetrain somewhere. Car has no vibration when not moving, even if engine is revved up. The vibration is still there even when the transmission is put into neutral and the car is coasting. It becomes noticible around 25 MPH, and increases with speed. Sometimes it seems like the vibration will go away when turning left, but comes back when going straight or turning right. Anyone have a similar problem, or any idea as to what this might be? My best guess is either a bad CV joint, or wheel bearing. The car has close to 170,000 miles on it.
Any help would be much appreciated.
Thanks
cubcadet149 is offline   Reply With Quote
Old 06-18-2009, 09:43 PM   #2
Growser
Growser is on a distinguished road
Growser's Avatar
Default Re: 1995 SL2 Front End Vibration
Classic signs of a bad bearing. Replace them in pairs (both sides) then get an alignment. This is one of the better posting I found with directions. Scroll down into the middle of that posting for pictures. http://www.saturnfans.com/forums/sho...light=bearings
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Growser is offline   Reply With Quote
Old 06-23-2009, 06:59 PM   #3
cubcadet149
Thanks for your opinion. I talked to a friend who has replaced wheel bearings in several of these cars and he also thinks I have a bad bearing. I will do some more investigation and maybe tear into it later this week.
Old 07-06-2009, 09:19 PM   #4
cubcadet149
Problem fixed. Pressed the old bearing out and the new one in at work with the help of my boss. Cost $52 for one at O'Reilly Auto Parts.
Tags
cv joint, front end, transmission, vibration, wheel bearing
'02 SL2 Front end vibration luvme2tymes S-Series Tech 8 06-13-2009 07:12 AM
'01 SL2 Front end vibration/shimmy shake......HELP! keller9431 S-Series General 2 12-25-2008 01:40 PM
91 SL2 has bad front end vibration when braking chrisr123 S-Series Tech 3 09-23-2008 09:00 PM
98 SL2 front end vibration saffire64 S-Series General 2 08-29-2007 04:35 PM
Front end vibration golftango Ion General 1 09-26-2004 02:21 PM
