Old 09-28-2019, 01:02 PM   #1
orins
orins is on a distinguished road
2007 VUE 3.5L
Default 2007 AWD Vue Wheel Bearing Questions
Hi All,
From a bit of research sounds like I have a wheel bearing just starting to go. Whining noise most noticeable from 40-60 MPH...no other symptoms yet.
Does anyone have advice on how to identify which wheel bearing is going? I read that checking the wheel for play (the traditional method for identification) often doesn't work with this vehicle.
Also, I've come across some "too good to be true" TRQ wheel bearing assemblies online, ($99 for set of 2, $180 for set of 4), does anyone have experience with these? I know...you get what you pay for...but curious if anyone has first hand experience.
Thanks for the help!
orins is offline   Reply With Quote
Old 10-01-2019, 08:33 AM   #2
Saturn072014
Saturn072014 is on a distinguished road
Default Re: 2007 AWD Vue Wheel Bearing Questions
I've never had good luck with cheap off brand wheel bearings lasting very long.
2009 XE 2.4 Saturn Vue.
Saturn072014 is offline   Reply With Quote
Old 10-01-2019, 05:40 PM   #3
Vue6
Vue6's Avatar
2006 VUE Red Line
...Timken is your best bet for wheel bearings, autozone specials a second pick. Regardless , if you do it yourself , clean and lube with lots of antiseize to make changing them in the future easier, just my.02, DC
Old 10-03-2019, 03:51 PM   #4
orins
2007 VUE 3.5L
Thanks for the input guys!
awd, vue 07, wheel bearing
Bad Front Axle Bearing (Not wheel bearing) ? cjhsa Vue General 19 08-08-2017 08:56 PM
Ion 2007 bearing&hub bestiol85 Ion Tech 2 03-11-2011 07:57 AM
06 Front Wheel Bearing Questions Venomized Vue Tech 22 07-18-2010 09:10 PM
Wheel bearing noise that isn't the wheel bearing? shelby987 Vue Tech 0 06-23-2010 11:16 PM
CV Joint and Wheel Bearing questions batmobile S-Series Tech 3 12-08-2006 02:02 PM
