Old 03-01-2018, 10:51 PM   #1
cookie1400
cookie1400 is on a distinguished road
2004 VUE 3.5L
Default Constant velocity joint on drive shaft
Hey guys,
Had a vibration in drivetrain changed I joints center bearing is being changed by a shop right now. But I noticed the cv joint that connects to the ptu moves side to side and up and down. I know itís a plunging type cv joint so the in n out is normal. But is the other movement normal?
Any thoughts? 2004 AwD V6 Vin 4
Thanks
cookie1400 is offline   Reply With Quote
Old 03-03-2018, 03:35 PM   #2
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
Default Re: Constant velocity joint on drive shaft
Normal, it slides in and out and pivots.
Saturn Vue: The 250 HP tupperware
newbievueowner is offline   Reply With Quote
center bearing, cv joint, driveshaft, u joint
intermediate shaft joint swap info needed fjordman1995 S-Series Tech 0 05-06-2015 01:25 PM
Separating the steering U-Joint and shaft FenderGuitars77 Ion Tech 3 01-11-2012 01:06 AM
TAAT End Cover CAUTION Ball Joint Removal (SA9132S; see also Input/Output Shaft Nuts) onehoop S-Series Tech 5 11-24-2009 04:16 PM
Help with drive side lower ball joint replacement Kegabeer S-Series Tech 7 05-21-2008 01:09 AM
04 AWD Drive Shaft vibrates at 38+ Jldet5 Vue General 24 11-09-2004 10:19 PM
