Old 03-28-2012, 12:46 AM   #1
badbobby
badbobby will become famous soon enoughbadbobby will become famous soon enough
Default rear wheel bearing
I have a faint clicking noise when I rotate the wheel with the brake drum removed--checked both sides and the noise is same on both sides--should there be no noise at all or is it normal to hear a faint click in the bearing? There is no movement when I try to move the wheel back and forth top and bottom and side to side. 1997 saturn sl 4 dr sedan sohc.175,00 miles.
badbobby is offline   Reply With Quote
Old 03-28-2012, 02:01 PM   #2
SC2Sick
1997 SC2
1995 SW2
Default Re: rear wheel bearing
Raise up your rear end and spin the wheels and listen for noise. It may help to use a mechanics stethoscope ( http://www.autozone.com/autozone/acc...ier=70131_0_0_ ) to listen for noise. Even if you do end up having to replace one it's very, very easy anyways.
I'm one to put wheel bearings off until I have to deal with them so I guess I've never really inspected one with a faint clicking..
sixthsphere.com owner
2002 Saturn SC2 - RHD
wheel bearing
Rear Wheel Bearing, ABS or no ABS? twhitney S-Series General 17 08-28-2007 12:51 PM
rear wheel bearing? gaurdien Vue Tech 9 05-13-2007 07:42 PM
Right Rear Wheel Bearing R&R Red97sc2 S-Series Tech 14 12-14-2006 02:55 PM
WTB: rear right wheel bearing BobDobbs Classifieds 2 05-05-2004 06:05 PM
DIY: Rear Wheel Bearing Son93SL2 Miscellaneous Tech 0 03-15-2003 12:46 AM
