Old 04-23-2006, 08:31 AM   #1
ilee
ilee is on a distinguished road
2001
Roll Eyes heater core L300
I have a 2001 L300 that the O-rings and pipes were reolaced in the heater core, now I have antifreeze running on the ground when car is runningand there is smoke coming from under the hood, I'm confused because now they say it needs a new water pump and timing belt has any one had this problem?
Add to ilee's Reputation
Rate the quality of this post and help ilee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ilee is offline   Reply With Quote
Old 04-23-2006, 01:49 PM   #2
1stSaturnowner
1stSaturnowner is on a distinguished road
1stSaturnowner's Avatar
2001 L-Series 2.2L Sedan
Default Re: heater core L300
o-ring and pipes were what?
Who said you need a new water pump and timing belt?
Please provide some details from before this happened to when you took it too the shop!!
year/make/model/engine size!
Add to 1stSaturnowner's Reputation
Rate the quality of this post and help 1stSaturnowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1stSaturnowner is offline   Reply With Quote
Old 04-23-2006, 06:30 PM   #3
AnotherSaturn
AnotherSaturn is on a distinguished road
2006 ION-3 Quad Coupe
1995 SW2
How many miles on your car? Who is the "they" you speak of, a Saturn dealer?
Since it sounds like you had it looked at by a professional somewhere, I would listen to their advice. The most common coolant leak resides from a coolant hose. Both my S-series cars had the upper hose burst on me. Water pumps are also common leaks in higher mileage cars.
The water pump is located in the same compartment as the timing belt on your engine. L300s have a 3.0L V6 engine that has a timing belt as opposed to a timing chain. Service interval for this belt is every 100k. It is around $800 for belt replacement alone. Many on this board would recommend having the water pump replaced at the same time as it is only 4 more bolts once access is gained to the timing belt. A little more expensive to have both repairs done at once, but substantially less than both repairs done separately. Water pumps are almost guaranteed to fail once you start hitting the higher miles in a car.
From my understanding if a bad leak develops from the water pump, it can cause the timing belt to slip resulting in valve damage to your car (ie costly repair). Get this taken care of as soon as you can.
If you're curious to learn a little more about the engine powering your L, go to http://www.reference.com/browse/wiki...gree_V6_engine . It is a unique engine.
Hope that helps a little!
Add to AnotherSaturn's Reputation
Rate the quality of this post and help AnotherSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AnotherSaturn is offline   Reply With Quote
Old 04-23-2006, 07:00 PM   #4
1stSaturnowner
AnotherSaturn, good advice, until you got a little off-topic in the last paragraph! However, thank you for get off topic. It was very informative. Especially, the longitudital(sp!) V engines!
Old 05-02-2006, 07:32 PM   #5
ilee
2001
2001 l300 4DR V6
Old 05-03-2006, 03:59 PM   #6
1stSaturnowner
2001 l300 4DR V6
Okay, thanks, did you get the new timing belt and water pump replaced?
I don't know why you would need a new timing belt, unless one of two reasons:
1)It snapped!,
2)The car's belt is showing signs of need to be replaced, or
3)It is over 100, 000 miles.
Can you tell me why you had the hoses replaced for the heater core, and who replaced them?
If you are leaking antifreeze from underneath the hood then you should be able to pinpoint were is coming from?
D.J.
Help with Heater Core SaturnSSteach S-Series Tech 10 07-29-2011 11:42 PM
Used Heater Core Okay? Burgertime631 S-Series Tech 4 02-21-2007 12:46 PM
Help please...heater core? lcdrgas L-Series General 7 02-04-2007 09:17 PM
L300 Leaking Heater Core piratepress L-Series General 5 12-30-2004 08:41 PM
Heater Core?? beensmoked L-Series Tech 2 12-29-2004 11:25 PM
