Old 11-24-2007, 11:26 PM   #1
Kevin 2007 XR
Kevin 2007 XR is on a distinguished road
Kevin 2007 XR's Avatar
2007 Outlook XR
Default How to Install OEM Navigation into the Outlook - An Illustrated Guide
This week I installed the factory Navigation unit in place of the factory radio with the Advanced Audio Package.
We do not have the rear DVD system.
The whole process took about 1.5 hours to do. the hardest part is getting the courage to tear apart your new car. The second hardest part is fishing the GPS wire through the dash.
If you have good skills with tools and take your time, it is a pretty easy job to do.
Please ask me any questions about the install and I will try my best to help you.
Only a few hand tools are needed:
Add to Kevin 2007 XR's Reputation
Rate the quality of this post and help Kevin 2007 XR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin 2007 XR is offline   Reply With Quote
Old 11-24-2007, 11:28 PM   #2
Kevin 2007 XR
2007 Outlook XR
Default Re: How to Install OEM Navigation into the Outlook - An Illustrated Guide
Old 11-24-2007, 11:29 PM   #3
Kevin 2007 XR
2007 Outlook XR
Old 11-24-2007, 11:30 PM   #4
Kevin 2007 XR
2007 Outlook XR
Old 11-24-2007, 11:32 PM   #5
Kevin 2007 XR
2007 Outlook XR
Be sure and tape the blue connector AND a little down on the foam covered wire area so you don't rip the connector off when you wish the GPS wire through the dash.
Old 11-25-2007, 07:25 PM   #6
che10234
che10234 is on a distinguished road
Wow, thanks! I'm picking up a used 2007 XR and I was hoping to find this information.
If I understand correctly, there are 2 wires to fish through the dash? The GPS antenna as well as the radio antenna ?
Chris
Add to che10234's Reputation
Rate the quality of this post and help che10234 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
che10234 is offline   Reply With Quote
Old 11-26-2007, 12:33 AM   #7
dwdokc
dwdokc is on a distinguished road
2007 Outlook XR
Excellent write up Kevin. I have been wondering how difficult it would be to start changing out speakers - with your photos I see it is not too tough. I may even undertake changing to the Nav unit now.
During the course of changing your head unit, did you happen to check out the subwoofer? Is it something you could see down through the dash opening? I would really like to change the sub out in my Outlook for something like a JL Audio sub.
Add to dwdokc's Reputation
Rate the quality of this post and help dwdokc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dwdokc is offline   Reply With Quote
Old 11-26-2007, 09:18 AM   #8
Kevin 2007 XR
2007 Outlook XR
Sorry, I did not look at the subwoofer. If it is below the radio, you only probably need to remove the upper storage bin and maybe the radio bezel.
Old 11-26-2007, 04:46 PM   #9
che10234
Hi Kevin,
Why do the A pillars need to be opened up? I don't understand what you are doing on the photo that says "Put a loop at the end of yout fish wire". Are you sending a wire FROM the center of the dash TO the side pillar in order to pull something back ? If so, what are you pulling back?
Thanks!
Chris
Old 11-26-2007, 04:57 PM   #10
che10234
Ahhh, forget it, i got it.
I thought the GPS sensor was sitting right above the center console, under the storage bin, but I see that's it actually off the the passenger side, beneath the cowl.
So the pillars come off so you can remove the cowl. And you fish a wire through to grab the blue end of the GPS sensor wire and pull it back.
Old 11-27-2007, 09:05 AM   #11
Kevin 2007 XR
2007 Outlook XR
You hit it exactly right. The A pillars hold down the cowl panel on the ends.
Good luck if you do it, it's not so bad, and to me worth saving about $1300.
Old 12-04-2007, 09:37 PM   #12
MikeNSteph
MikeNSteph is on a distinguished road
OUTSTANDING WRITEUP! Very much appreciated, everyone vote for this post as an outstanding addition to the forum.
I would like to add that the part number that you have for the dvd version seems to have changed. The one you list doesn't appear in any online catalog or dealer lookup, but p/n 25816282 does. This is for the NAV/DVD part. I was unable to find your part number in any database or a cross reference index either, but the ebay seller you list does carry that part number, obviously since you have it. Just a search thing for other users to use. From gmpartsdirect, the nav/dvd radio is $1529, non dvd is $1341. Seems like the ebay seller you list has several of these offered right now for 800 bucks! nice! I'm all over it. Oh, by the way, if you don't have the Advanced Audio package, you likely will need to add the VSS wire, just an FYI.
Another, way less detailed, guide for this operation can be found here:
NOT AN EBAY AD, just a search link.
http://reviews.ebay.com/Enclave-Acad...:-1:LISTINGS:1
____________________________
'07 Outlook XR AWD
Silver Pearl
Luxury Package and almost everything else
Add to MikeNSteph's Reputation
Rate the quality of this post and help MikeNSteph reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MikeNSteph is offline   Reply With Quote
Old 12-04-2007, 10:50 PM   #13
Dalejr
Dalejr is on a distinguished road
Dalejr's Avatar
2007 Outlook XR
The unit with the p/n 25816282 has blue lites behind the buttons not orange that matches the rest of the dash lights in the Outlook.
2007 Outlook FWD XR Pearl Silver, Convnience Pkg, Touring Pkg, Premium Trim Pkg, Trailering Pkg, Dual Sunroof, Molded Mudguards
2006 Eclipse GT 6-Speed UV Blue Pearl, Premium Sport Pkg, Accessory Pkg
Add to Dalejr's Reputation
Rate the quality of this post and help Dalejr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dalejr is offline   Reply With Quote
Old 12-05-2007, 11:57 AM   #14
MikeNSteph
Wow, good to know! I might go ahead and get the blue lighted one, might be a good contrasting color against the orange. If I can find a place that has the orange p/n for that price I'll go that route, though. If anyone finds a good source for it, post up. Seems the A and T dealer on ebay is the only one really offering it for less than GM's new part price.
'07 Outlook XR AWD
Silver Pearl
Old 12-05-2007, 08:56 AM   #15
Kevin 2007 XR
2007 Outlook XR
I actually used this eBay guide as a basis for doing my installation. Without it I may have never tried to do it. I thought that by posting more details pictures of the install on the Epsilon platform forums like this one will inspire more people to do this. Seems like its working!
Old 05-24-2018, 05:02 PM   #16
BlueGohan14
BlueGohan14 is on a distinguished road
2007 AURA XE
2008 Outlook XR
Amazing thread Kevin. Thank you for your incredible instructions. This is defiantly something that I would like to attempt very soon. I just purchased a used 2008 Outlook XR. It has everything but the NAV unit. I was just wondering if you thought about adding the back up camera too? I'd like to do both, but don't know how hard it would be to add the camera. Either way, thanks for the info.
Add to BlueGohan14's Reputation
Rate the quality of this post and help BlueGohan14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlueGohan14 is offline   Reply With Quote
Install OEM Navigation in Non Nav 08 Vue RL BigD_Redline 2008 Vue 14 12-29-2009 10:35 PM
08/09 Vue OEM Navigation Unit for Sale BigD_Redline 2008 Vue 0 12-13-2009 04:24 PM
Navigation Install oachalon Aura General 16 10-02-2007 12:01 PM
Anyone used the Outlook navigation system yet? Sempuukyaku Outlook General 10 02-06-2007 01:29 PM
Interior Picture of an Outlook w/o navigation? cecoffma Outlook General 9 12-12-2006 09:56 AM
