Old 10-16-2020, 07:40 AM   #1
Rix Aura
Rix Aura is on a distinguished road
Default Coolant fan stayed on after turning off the car
Hi all,
Yesterday when I got home after about an hour drive in mixed traffic, the coolant fan remained on after I turned off the car, Aura 3.6 XR. I don't recall this ever happening in the three years I've owned it, should I be concerned? Thanks in advance for any help.
Rick Shaw
2008 Aura XR
2000 Trans Am convertible
2005 Victory Vegas
Rix Aura is offline   Reply With Quote
Old 10-16-2020, 01:49 PM   #2
Default Re: Coolant fan stayed on after turning off the car
Review your owner's manual. Many vehicles with extensive electronics make use of them in advanced ways. GMs factory antitheft system uses on board electronics (ecm and bcm) to disable engine functions with the press of the remote to Lock all doors.Thieves unable to turn on ignition would encounter a non functional car and leave. Another is detecting engine heat soaking after a hot and humid drive in local traffic with ac running. With the engine running hotter, chances of overheating are minimized with cooling fans running when needed but when parked in this condition, electronics are still monitoring coolant temps. With higher coolant temps already bordering on overheating without cooling fans running, the engine computer has programming to ensure overheated engines are cooled down by automatically turning on cooling fans after engine shutdown for a few minutes. Coolant temps must be high enough for this programmed event to occur. Once enabled, fans run until temps drop to another level before the ecm turns off fan cooling. Most Saturns with this feature are timed to no more than three minutes with ignition off to prevent draining the battery. If fans run longer after engine shutdown, this would be cause for concern.
VCX NANO
Old 10-16-2020, 07:16 PM   #3
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
If there is no check engine light and the fans turned off on their own, it's likely normal but check your coolant level. Keep an eye on the temperature gauge for indication that it may be reading incorrectly.
Like fdryer indicated, there are conditions programmed into the computers which will cause the cooling fans to continue running after the ignition is switched off.
Coolant fan not turning ON, replaced FAN.. bad ground on Fan relay cnceric S-Series Tech 8 08-29-2020 02:35 PM
coolant overflow after turning engine off e1geo S-Series Tech 17 02-12-2013 11:45 PM
2005 L300: Coolant smell after turning engine off jwblue L-Series General 7 05-01-2011 03:13 PM
Coolant Fan Not Turning On Creamed Up S-Series General 8 08-16-2010 09:08 AM
Air Bag light stayed on Mike Stallings L-Series General 1 11-24-2005 02:26 AM
