Old 05-07-2019, 11:28 AM   #1
VueGuyz
VueGuyz is on a distinguished road
Question Fuel Delivery Issue on 08 Vue 3.5l after Engine Change
Having a problem getting fuel to start after engine change. Engine starts and runs when fuel pump is jumped with 12v. No codes in OBD. Any suggestions ?
Add to VueGuyz's Reputation
Rate the quality of this post and help VueGuyz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VueGuyz is offline   Reply With Quote
Old 05-07-2019, 06:33 PM   #2
Channeler1
Channeler1 has a spectacular aura aboutChanneler1 has a spectacular aura aboutChanneler1 has a spectacular aura about
2005 VUE 2.2L
Default Re: Fuel Delivery Issue on 08 Vue 3.5l after Engine Change
If you're sure the Fuel Pump is good, I'd go right to the ECM on that one!
Not sure of the check procedure But it sounds like the fuel pump is not getting powered on after the Key-On Signal!
If you don't have any kind of kill switch or Alarm shut off - I'd check that .
Add to Channeler1's Reputation
Rate the quality of this post and help Channeler1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Channeler1 is offline   Reply With Quote
Old 05-07-2019, 09:46 PM   #3
If the engine starts and runs except for the fuel pump, the ecm is more or less fine since the entire EFI system runs off the ecm.
Did you replace the ecm or not? Checked for any blown fuses (fuel pump)? Is security flashing when starting?
Old 05-08-2019, 08:43 AM   #4
atikovi
TheftLock issue?
Add to atikovi's Reputation
Rate the quality of this post and help atikovi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-08-2019, 02:05 PM   #5
VueGuyz
I will look into the theft lock issue. Thanks
Old 05-11-2019, 11:29 PM   #6
VueGuyz
Passlock reset did not work. No power to the Fuel System Control Module at all. I checked and changed all relays and fuses to fuel pump. Must be a bad wire or ground somewhere. All suggestions are appreciated. All plugs on harness are intact and connected. Any ideas where to focus next
Old 05-12-2019, 07:42 PM   #7
bern
bern is just really nicebern is just really nicebern is just really nicebern is just really nicebern is just really nice
2004 ION-2 Sedan
If the security light Is on For bulb check But off After bulb check The security system is OK, Key on engine off is the check engine light on? Does the fuel pump momentarily have power when the Ignition is first turned on? Is the FSCM 10 amp fuse and the FSCM 20 amp fuse good with power (Both are in the instrument panel fuse block ). are the G105 and G106 grounds attached to the engine Left rear corner of the engine Just below the rear of the left cylinder head (head closest to the front of the vehicle)
Add to bern's Reputation
Rate the quality of this post and help bern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-14-2019, 11:32 AM   #8
VueGuyz
Security light is off. Only engine code is U109. No power to fuel pump at all. Im on work travel will recheck fuses and ground wires this weekend. Thanks for all advice
Old 05-18-2019, 08:26 PM   #9
VueGuyz
Problem fixed thanks....current checked at fuse...found broken fuel pump wire under front seat. Reattached broken wire and car is running nicely. Thanks for all the tech help.
Fuel delivery issue dwarffortress S-Series Tech 17 04-07-2012 04:45 AM
Fuel delivery or Spark or? mfedenko S-Series Tech 6 12-03-2009 12:59 AM
fuel delivery problems frankeieio Vue Tech 6 02-04-2009 03:45 PM
96 SL2 Possible Fuel Delivery Problem ecaryn S-Series General 13 05-23-2006 10:06 AM
fuel delivery modes emailer33 S-Series General 1 01-31-2005 12:14 PM
