Old 12-05-2019, 06:08 PM   #1
fjordman1995
fjordman1995 is on a distinguished road
1993 SL2
1996 SC1
Default Rear drum backing plate swap (what years fit)
Need to replace the drum backing plates on 1995 sc1. Anyone know what years will fit?
Thanks,
Warren
Add to fjordman1995's Reputation
Rate the quality of this post and help fjordman1995 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fjordman1995 is offline   Reply With Quote
Old 12-05-2019, 10:51 PM   #2
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Default Re: Rear drum backing plate swap (what years fit)
Any S-Series from 93-02 will work. IIRC, 91-92 Did't Have the option for rear discs.
EDIT: Totally miss read your post, thought you where converting to discs and needed the dust shield. Any year should work, 91-02
97 SL2, auto, 117K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-06-2019, 01:41 AM   #3
TomM96
Maybe consider replacing the entire rear suspension with one from a wrecking yard which happens to have Way Less rust... might save maintenance time in future.
I have dutifully renewed backing plates on other vehicles... but maybe another option.
Add to TomM96's Reputation
Old 12-08-2019, 10:20 AM   #4
fjordman1995
1993 SL2
1996 SC1
Thanks for the info, anyone know if that is in the swap guide? Or is there a way to search JUST the swap guide thread?
Took the plates off the spare (collision rearranged) 1996 sc1, they were better but still 3-5 out of 10 and blasted and will repopulate the missing metal por 15 for now (before/after pix to follow) if anyone's interested
Warren
Old 12-08-2019, 11:34 AM   #5
Waiex191
Waiex191's Avatar
I know of no way to search one thread. Of course we are interested - this sort of thing is why we are here! Backing plates on my '98 are trash.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 12-08-2019, 11:44 AM   #6
IIRC the backing plates are sandwiched between the bolt-on rear wheel bearing and the knuckle...as long as the undersized 10mm hex-head bolts (heads should be at least 12mm for the torque required) come out fine it should be a super simple swap.
They should also be the same '91-'02 so whatever you find in rust-free condition should swap on fine.
Old 12-09-2019, 09:16 AM   #7
trottida
trottida's Avatar
At the top right of this thread in the column header there is a search this thread option. I have no idea if it works though.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 12-09-2019, 01:55 PM   #8
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
It works I use it often
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is offline   Reply With Quote
Drum Brake Backing Plate NLA? DoriftuEvo S-Series Tech 1 09-27-2016 09:10 AM
L200 Rear disc conversion. (or a new Left drum backing plate ) DakRatFink L-Series Tech 8 03-12-2014 09:12 PM
Bent drum brake backing plate (I'm an idiot) jzambon S-Series General 6 02-18-2014 07:22 PM
Need rear drum backing plates for 94 SL2 Ray Dog S-Series Tech 7 06-20-2012 09:26 PM
Rear disc swap, removing drum assembly. FenderGuitars77 S-Series Tech 0 05-01-2011 03:06 PM
