Old 03-18-2015, 03:29 PM   #1
kevster0522
kevster0522 has a spectacular aura aboutkevster0522 has a spectacular aura about
kevster0522's Avatar
Question 95 SL1 Cruise Installation
Hey everyone! I wanted to take up a project to install cruise in my 95 sl1. I recently ran to the junkyard and grabbed a cruise module from a 94 sl1 and the steering switches from a 97 sl1. I plugged them both in and tried running without the airbag so I know it works before I cut up my steering wheel. So far I've got a light on the steering switches when I turn cruise on so thats getting power but the module seems to not be working correctly.
There is a lot of different information about cruise control and whether it gets its info from the pcm or not. I believe that because I got the module out of a 1st gen saturn, it doesn't need pcm information. I have no idea whether my car is actually wired up to communicate with a 94 module but everything fit well and it attached to the gas pedal correctly.
I'm wondering if the issue is because I'm missing a clutch switch. I have the safety switch on the floor for starting the car but I did a little research and I think there might be a switch above the clutch to tell the cruise when the clutch is all the way up. Can anyone confirm this info?
I attached some pictures of the clutch. First picture is of a mysterious cable looming above the clutch and the second is of the switch on the floor. Anyone know if I can test this mystery cable by jumping it and seeing if my cruise works?
Thanks in advance
1995 sl1
Add to kevster0522's Reputation
Rate the quality of this post and help kevster0522 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevster0522 is offline   Reply With Quote
Old 03-18-2015, 03:46 PM   #2
kevster0522
Default Re: 95 SL1 Cruise Installation
Just tried jumping that cable with a paperclip. It didn't have any affect on the cruise. Now I'm not sure what to do next.
1995 sl1
Old 03-18-2015, 09:44 PM   #3
Did you drive the car to see if the cruise control works?
It should not set and hold a speed until you hit about 30 MPH.
Add to ssicarman's Reputation
Old 03-18-2015, 10:06 PM   #4
SL19302
SL19302's Avatar
2002 SL1
If the cruise module is in fact good and it doesn't engage the PCM might need to be programmed to see the cruise option.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 03-19-2015, 11:19 AM   #5
kevster0522
Yes I did try. I went up to 45mph but it would not engage.
1995 sl1
cruise control installation racinginblood S-Series Tech 5 09-01-2011 10:05 AM
Cruise control installation problems TMA S-Series Tech 4 12-27-2008 06:28 PM
Cruise Control Installation and PCM Question, here we go again xserver S-Series Tech 3 07-03-2008 08:57 AM
Cruise Control Installation Zvolen S-Series Tech 5 03-11-2008 10:51 AM
Aftermarket cruise control installation... ? Scyan S-Series Tech 7 01-15-2003 01:58 PM
