#1 | ||||
![]() ![]() Join Date: Jan 2015
1997 SL1
![]() I've recently bought a Saturn and would like to install a dashcam in my car for insurance and liability reasons but I don't see any power ports I can use. Does anyone have any idea how to get a dashcam working in these cars?
I drive a 1997 SL1 SOHC.
#2 | ||||
![]() Join Date: Feb 2011
1995 SL
1995 SW2
![]() Power has to come from the battery, current wiring can't support additional constant loads.
... '95 SL 5 Speed 220k - DD '95 SW2 5 Speed 230k - Gone! '95 Camaro Z28 - Project '00 Tahoe Z71 - Truck stuff
#3 | ||||
1997 SL1
![]() I was thinking of possibly removing the cig-lighter and seeing if it's possible to wire in a power port in its place. The thing is that I am not sure what power it provides to the cig-lighter.
#4 | |||||
![]() Quote:
![]() Wire to the battery. Post pictures and I will follow your lead an install one in my car ![]() ... Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
#5 | ||||
![]() I wired up a two outlet power port and mounted it on the passenger side of the center console, looks pretty good and powers the camera and sailfawn charger. The ground is tied into the brackets under the radio and the power source comes straight off the uhjb positive post. Same line powers the radio and a few other not-stock loads.
#6 | ||||
![]() When the car exhibits signs of being possessed by ghosts with a bad attitude you will know why.
#7 | ||||
![]() I have to believe that a dashcam will use a tiny amount of power. Can you mount it to the windshield with a suction cup (or whatever) near the mirror and run a wire to the dome light?
#8 | ||||
![]() The DOME Light is powered from the exact same fragile circuit as the lighter socket.
#9 | ||||
1997 SL1
![]() To anybody that's interested, I found a nice and easy guide on how to install a power source by connecting it to a modified fuse that plugs in to the fuse box. I think I will go with this.
#10 | ||||
1997 SL1
![]() http://thedashcamstore.com/installation-kits/
-Not sure which kit will work best for my car. http://thedashcamstore.com/advanced-...-installation/
#11 | |||||
![]() Quote:
Either one of those is a 1 amp continuous load on the circuit.
#12 | ||||
1997 SL1
![]() So I guess the only option is to tap in to an existing wire? These power sources are only 5V, which isn't much but how many amps? I'm not an electrical engineer haha.
#13 | ||||
![]() You run a new wire to the battery. Search above will bring up several lengthy posts on exactly how to do this so you can have all your toys and not have electrical isues. If you are using the lighter socket for chargers you are already working on a failure. The car does not run without a running fuel pump.
#14 | |||||
![]() Quote:
![]() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Spy Cameras shown on the DashCam Store: When running direct to the battery, the key on, camera on feature will not work will it? ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ...and, I say to everyone again. If you are perturbed ![]() ![]() ... Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
#15 | |||||
![]() Join Date: Jul 2011
![]() Quote:
However, if you run the wire from the battery through a relay that is controlled by a line that is only powered on through ignition then you can have this functionality without plugging and unplugging the cord. I wonder if you could use the radios power on signal wire for this purpose? I dont think the relay would add too much load to this line, solid state would probably be a good choice. If this function is truly a must have then this is where I would start; in summary: Hot wire from battery to relay, relay signal on wire tied into the radios signal on wire, grounds to frame, hot wire from relay to 5v transformer for camera. The rest is plug an play. If you need I could draw you a basic diagram and help you pick a relay. Cost for this will be on par with their kit, and will not lead to demonic possession in your cars electrical system. Disclaimer: I am no electirician, just a certified redneck with some small idea of how electricity works.
#16 | ||||
![]() I ran a 12 gauge wire from my battery to the interior of my car. Then in the footwell area, I wired up a relay to that wire, which is triggered by the accessory wire on my ignition. Inline with this, I installed a 5 amp ATC fuse. I have more than just the dashcam wired up to this wire though including a secondary USB charge port and multi-display in a custom overhead console I made. However, after all of this, it's nice that things power on when I turn the key.
... 2001 SL1 5spd - DOHC swap and MS in the works Bought 02/27/14 2000 SL 5spd Bought 04/05/05 Sold 06/14/10
Dashcam? | ninetynineSC2 | General Saturn Discussion | 2 | 02-07-2015 09:13 PM |
