Old 07-16-2018, 10:31 AM   #1
beaverplt
beaverplt is a jewel in the roughbeaverplt is a jewel in the roughbeaverplt is a jewel in the roughbeaverplt is a jewel in the rough
2001 SW2
Default Good battery, nothing works
Hi all, I have a problem that is probably addressed somewhere in this forums but I could not find it. This morning when I turned the key, nothing happened. No clicking or sounds at all. I assumed I had left something on, but when I put my charger on the battery. I found it was fully charged. Nothing in the car works. No headlights, no clock, no radio, nothing. I'm assuming I've got a problem with the ground. What should I check first? Thanks
Add to beaverplt's Reputation
Rate the quality of this post and help beaverplt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
beaverplt is offline   Reply With Quote
Old 07-16-2018, 11:26 AM   #2
Default Re: Good battery, nothing works
Problem is likely with the POSITIVE cable at the battery. Take your voltmeter and place the black probe on the engine block and the red on the red wire at the UHJB, NOT the battery bolts. If you read zero it is the positive cable that is not making good contact with the battery. Disassemble and clean.
Old 07-16-2018, 11:31 AM   #3
beaverplt
2001 SW2
What's the UHGB?
Old 07-16-2018, 12:57 PM   #4
beaverplt
2001 SW2
Never mind. Had a brain fart.
Old 07-16-2018, 07:15 PM   #5
beaverplt
2001 SW2
It turns out that the positive contact on the battery had so much corrosion I'm surprised it didn't fail sooner.
Which cell phone car mount works good for you? IT_Architect Vue General 11 01-20-2016 09:36 AM
no crank, good battery EchoMirage S-Series Tech 14 12-19-2015 10:12 PM
1996 Saturn SL1 No start, battery works. msdstc S-Series Tech 2 04-04-2014 11:40 PM
Dorman TPMS sensor-Works good OGC5 2008 Vue 10 02-04-2014 07:32 PM
Good Battery, no other power - anywhere (but...) finder216 L-Series Tech 8 12-02-2010 08:29 PM
