Old 10-19-2010, 09:27 AM   #1
Talgonadia
Talgonadia is on a distinguished road
Default 2005 Saturn Ion 2 problem
I have a 2005 saturn ion 2 with just under 80,000 miles.
I believe it is doing that no start / no crank problem or something similar. The car is a manual and in the colder mornings when I go to start the car it will not start, sometimes it will crank. The anti theft alarm & the check engine alarm will go on the car. The accessories in the car, radio, heater, and lights all seem to work. I go outside ten minutes later and she fires up like nothing happened.
I took it to a shop and they have tried the last few days to get the problem to duplicate and are not successful.
They said that i have a passlock sensor that is out or going out?.. They said it would be 200 dollars to fix it. I was just wondering if you guys knew how hard it would be for myself to fix it. I was thinking of just ordering a new ignition switch. I also live in WI and well its going to get colder here pretty soon.
Its just weird because the car will crank but not start.. which could be the signs of a bad starter?... but would that cause the anti theft alarm to light up in the car?
Talgonadia is offline   Reply With Quote
Old 10-19-2010, 03:29 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: 2005 Saturn Ion 2 problem
The ignition switch issue causes it not to even crank, sounds like you need to check your ground wires and positive wires.
Old 10-19-2010, 05:20 PM   #3
Talgonadia
I have checked them but I can do it again. If it were to be some wiring issue would that cause the anti theft alarm to appear? The light with the car and the lock in the dashboard?.
Old 10-19-2010, 07:16 PM   #4
2006 ion2
2007 ION-2 Sedan
I don't think so, but at the same time, the security system is designed to not even let it crank. You may have a combination of issues.
Old 10-19-2010, 07:43 PM   #5
Talgonadia
Default
Ok. if I recall correctly 80% of the time it cranks but won't start. About ten minutes later it starts...hmm well hhopefully the mechanics can get the symptoms to occur.
2005 VUE steering problem? sl2hippie Vue Tech 1 07-06-2010 10:42 PM
2005 Saturn ion 1 radio problem question csf559 Ion Tech 6 06-15-2010 09:05 AM
saturn ion2 2005 intake maf sensor problem mattcritt Ion Tech 4 11-24-2009 01:47 PM
2005 Ion Driver Window Problem jesposito45 Ion Tech 3 08-26-2009 04:45 PM
2005 Relay 3 - DVD Problem Mark Gambo Relay Tech 5 02-26-2008 12:38 AM
