Old 10-31-2018, 10:15 AM   #181
Default Re: and so it begins....
Gen-2 gauge indication vs. actual temperature
GAGE Reading..........ECTS Temperature..........Event
.....1/4.................................150 F
.....3/8.................................192 F...................T-stat cracks open
.....3/8+................................195 F
.....1/2.................................212 F
.....9/16................................221 F...................Fan ON
.....7/16................................210 F...................Fan OFF coast to 205 F
NOTE. gauge mechanical accuracy is +/- needle width.
The Gen-3 is a digital signal that is used to drive the cluster indicator. The Gen-1 is a nonlinear gauge.
Old 11-08-2018, 12:30 AM   #182
trottida
trottida's Avatar
More updates to the 99 SL2. I installed seat heaters in it a couple weekends ago.
I had done a write up for my other car some time ago and I took the time to enhance that thread with photo instructions on how to set up the switched power from the UHJB. The thread is called Seat heater install with pictures.... and the post showing how to set up the fused and switched power wire from the UHJB is within Post 8.
Here are some photos of the switch location from that post to document this upgrade
2001 SL1 MT (423,500 km @ 10/2018)
1999 SL2 MT (267,940 km @ 10/2018)
2011 Suburban LT (116,506 km @ 10/2018)
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Add to trottida's Reputation
Old 11-08-2018, 09:28 AM   #183
Nice job on the install!
Saturn in Batman Begins sallydriver S-Series General 9 12-14-2013 01:51 AM
So it begins: Rebuilding a 1995 SC2 RalliArt16 S-Series Tech 441 05-08-2013 09:55 AM
GM's Rebirth Begins Now eelfliw General Saturn Discussion 0 05-31-2009 10:07 AM
Here's Where The Fun Begins Racer93 S-Series Tech 5 03-15-2008 09:35 AM
the door makeover begins! BlueIonDriver Ion General 31 05-06-2004 11:20 AM
