Old 04-16-2021, 04:44 PM   #41
BrandonKastning
BrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the roughBrandonKastning is a jewel in the rough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench Re: 2001 Saturn L300 (L81/3.0L V6) - Lower Intake Manifold Gasket/Thermostat Replacem
Hey everyone!
I believe today is the day that I succeeded on the thermostat.
If anyone believes otherwise by looking at the pictures; please let me know. I couldn't get the extension hose tube to move forward anymore with it bolted down and torqued to 12 ft. lbs.
In the beginning galleries you can see the comparison between the 3 thermostats. The original; the "knock off" that will NOT work with a 2001 Saturn L300 3.0L V6. Amazon "matched it" with my vehicle make, model and year (apparently it doesn't always work).
The bolts are identical in length; (the original GM ones I ordered and the old strange 13mm bolts I pulled from the 1st thermostat).
I used both GM replacement E12 bolts and torqued them to 12 ft. lbs after ratcheting them down equally before switching to a torque wrench.
The whole process I banged up the ear fdryer mentioned and cautioned (re-iterated); it is fragile if you are prying down on it with a pry bar.
Some tricks are, again the hose maneuvers (pushing down - will bring the extension tube upwards so that you can slide the thermostat in).
The difference between the original GM thermostat and the "knock off" amazon one... are two differences that make it incompatible with my car.
1) The height of the [right side] bolt foundation.
2) Not as "skinny" ; in the previous galleries of me installing the "knock off" thermostat; I was able to use a Pry Bar for the hose in front -- popping up the extension tube to slide in the replacement. (This does not work on the GM original replacement) ; you MUST place the thermostat face down first; then press forward on the water tube and the metal bar "the ear" as fdryer called it.
Even once it's in; keep pressing as much as possible to ensure a snug fit. *I can't get mine anymore*. I pushed the dip stick backwards and toward the drivers side of the car and "the ear" is all the way forward now.
Looks solid!
Here are the following galleries.
Gallery A:
Best Regards,
~ Brandon Kastning
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
BrandonKastning is offline   Reply With Quote
Old 04-16-2021, 04:45 PM   #42
BrandonKastning
Gallery B:
Old 04-16-2021, 04:46 PM   #43
BrandonKastning
Gallery C:
Old 04-16-2021, 04:47 PM   #44
BrandonKastning
Gallery D:
Old 04-16-2021, 04:48 PM   #45
BrandonKastning
Gallery E:
Old 04-16-2021, 04:49 PM   #46
BrandonKastning
Gallery F:
Old 04-16-2021, 04:50 PM   #47
BrandonKastning
Gallery G:
Old 04-16-2021, 04:51 PM   #48
BrandonKastning
Gallery H:
Old 04-16-2021, 04:52 PM   #49
BrandonKastning
Gallery I:
Old 04-16-2021, 04:54 PM   #50
BrandonKastning
Gallery J:
Old 04-16-2021, 04:55 PM   #51
BrandonKastning
Gallery K:
Thank you everyone! saturnfans.com - Awesome for Saturn owners!
Old 04-19-2021, 09:31 AM   #52
BrandonKastning
Re-installation of the Lower Intake Gasket!
Tags
l300, l81, manifold gaskets, thermostat
2001 Saturn L300 (L81/3.0L V6) - Upper Intake Manifold + Spacer [Removal] BrandonKastning L-Series Tech 25 04-06-2021 11:03 AM
2001 Saturn L300 (L81/3.0L V6) - Pre-Question for Head Gasket DIY Replacement BrandonKastning L-Series Tech 49 03-09-2021 01:11 PM
2001 saturn SL series intake manifold gasket? Ethman L-Series General 1 03-23-2013 02:05 PM
2001 SL1 intake manifold gasket replacement sferguson S-Series Tech 4 03-04-2007 09:19 PM
2001 Intake Manifold Gasket Replacement between5and7 S-Series Tech 0 11-10-2006 04:38 PM
