Old 05-29-2018, 01:32 PM   #1
Patriots
Patriots has a spectacular aura aboutPatriots has a spectacular aura aboutPatriots has a spectacular aura about
Default Replaced tps on 01 SL2.. still idles high
I just replaced the tps on my 01 SL2 a week or so ago and it was fine until a few days ago. Now it will idle high after the car has been running for a while. When I shut off the car and restart it itíll run normal again.
Checked the connection of the sensor and everything looked fine. What could be causing this issue?
Patriots is offline   Reply With Quote
Old 05-29-2018, 01:52 PM   #2
Default Re: Replaced tps on 01 SL2.. still idles high
Where did the TPS come from? You may have a bad connector.
Old 05-29-2018, 01:57 PM   #3
Patriots
Company called standard motor products. Was bought off amazon.
Old 05-29-2018, 02:20 PM   #4
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
1996 SC2
Go back on Amazon and reorder the A/C Delco. Aftermarket sensors aren't worth the plastic they're molded with. You may also need to replace the connector.
-Robert
Old 05-29-2018, 03:14 PM   #5
That A/C Delco is also an aftermarket part. It will just cost you more money for the box. Go to the pick and pull and get a good one WITH the connector. The SMP is what is in the Delco box as well, or BWD which is the same as the SMP.
You probably have a failed connector. Spray it out with contact cleaner and very lightly put some silicone on the rubber seal, do not lube the pins, socket, or inside of the connector. Spray out the TPS socket along with the connector.
high idle, problems., saturn, sl2
idles high pac S-Series General 5 10-14-2011 09:56 AM
'94 SC1 idles at very high RPMs ivkowalenko S-Series Tech 6 10-12-2011 02:48 PM
'02 SL1 Idles high. Why? markdunavant S-Series General 2 06-28-2011 01:52 AM
Car idles high dubsl2 S-Series General 21 10-26-2006 09:58 PM
99 sc2 idles high and jumps a bit twincities S-Series Tech 1 07-06-2006 01:10 PM
