Old 07-20-2018, 10:23 PM   #1
J.W.
J.W. is on a distinguished road
2001 SL2
Default Range switch faulty ?
2001 SL 2, 187xxx miles., trans. flush and fluid change 2 days ago. Symptoms predate that.
Symptoms : Rare reverse slam, Also rare- seems to lose 4th gear..engine just revs with gas applied. shift to 3rd then to D and it is normal..even with starts and stops.
OBDII shows "transmission range sensor circuits malfunction" code- P0705
That shows on my reader and the same shows on Auto Zone's reader.
No other codes or problems show up.
It is adjusted correctly...starts only in park or neutral.
The ground wire is good...tested by substitution with new wire to ground.
How can I be certain the range switch is faulty ?
How can I test the 'other circuits' in the range system ?
Thank you for your help... JW
Add to J.W.'s Reputation
Rate the quality of this post and help J.W. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
J.W. is offline   Reply With Quote
Old 07-20-2018, 11:04 PM   #2
Default Re: Range switch faulty ?
Range switch is worn out. Replace it.
Old 07-20-2018, 11:41 PM   #3
J.W.
2001 SL2
Thank you , Nuc. With only 1 fault showing, I thought that had to be the case. The present switch is only a couple months old...new does not mean good !
I sent a PM also...unrelated.
JW
Old 07-21-2018, 08:18 AM   #4
Aftermarket switches are hit or miss on quality. Those are very small pin contacts in that switch and multiple switches are closed/opened to encode the selected position. General recommendation is to pull an OEM switch out of a JY if you can find one.
Old 07-21-2018, 12:10 PM   #5
Try adjusting it again before throwing another switch at it; adjustment is cheap and easy. Not starting except in P or N doesn't prove it is presently adjusted OK; the start interlock contacts are totally different from the shift contacts and may be more tolerant of poor adjustment.
PS: I think your other symptoms are not related to the switch, the trans should not slam or allow the engine to free-rev even if the range switch is completely dis-connected. More testing is needed, but I expect a VB replacement is also in your future.
Add to billr's Reputation
Old 07-21-2018, 08:27 PM   #6
J.W.
2001 SL2
I bought a new switch at Autozone. It is marked "Saturn" (cast in) with a part number 24022303 below the name.
The box says made in Japan.
Can this really be a Saturn part, but made in Japan ?
I know.... Wishful thinking ? ?
I just read the label on the plastic wrap that held the switch... It does indeed say "Genuine GM in one corner, and General Motors Corp in the bottom right. Along with pn .. Looks like I got lucky ! ? (It also says Made in Japan)
It is easy enough to re check the switch alignment prior to replacing...if required. Good idea in any case.
Thank you all for your reply's... I shall consider them all.
JW
Old 07-21-2018, 09:35 PM   #7
Many OEM Saturn parts came from Japan. You indeed may have gotten lucky. There is a very specific alignment procedure and there is no rocking back and fort allowed. There is a scanned copy in my photo gallery if you do not have one.
You also should consider a replacement valve body before something breaks.
Range Switch Shenanigans Nekomimi S-Series Tech 12 10-04-2014 07:59 PM
Automatic Range Switch, different!? KingRex S-Series Tech 4 03-17-2009 07:31 PM
Faulty switch?? Timguy1008 L-Series Tech 1 02-26-2009 05:06 PM
Transaxle Range Switch\Neutral Start Safety Switch lonelywolf8588 S-Series Tech 2 07-20-2006 08:55 AM
Faulty rear defrost switch? I don't think so now! SpaceFrame Miscellaneous Tech 4 02-12-2003 11:40 PM
