#1 |
![]() Join Date: Oct 2022
Any advice on these new seals? They're brand new. Seems to be keeping the timing cover from getting full contact at the bottom. Any tips for this? The seals came in a felpro fron crankshaft seal kit. 2 rings for the oil pump and the big one for the crank. RTV instructs say don't torque but the bottom bolts won't go in. Are the seals not seated properly? Should I disregard the instructions and torque anyway? Just to snug the cover or no? Really hoping for some advice here. I'm almost done.
#2 | |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2017
1995 SW2
![]() Quote:
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018) 1994 Sl1 5spd: Inherited, Stock: 494,500 1995 Sl2 5spd: Retired Daily, Not Stock: 196,000 1995 Sw2 5spd: Daily, Stock: 105,000 |
#3 |
![]() Join Date: Apr 2010
Did you remove the oil pressure and suction seals from their respective cavities in the cylinder block?
Did you align the gerotor oil pump during front cover installation? Timing Cover.jpg Oil Press Port,Timing Chain, Oil Suction Port.jpg The front cover should sit flush against front of block using hand pressure with oil pressure and suction seals installed. Do not use bolts to close up excessive gap or timing cover will crack! Pressure/Crank/Suction Timing Cover Seals.JPG |
#4 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2014
Agreed. Do not use the bolts to force the cover to seat. While pesky to install while engine is in the car, have patience. I have always “trial run” the installation, before adding rtv. Is everything cleaned up nice and shiny? Including the alignment dowels? Maybe cover is not going on straight?
Bookmarks |
Oil Pump seals | Dale002 | S-Series Tech | 6 | 01-02-2017 06:50 PM |
Valve cover gasket--preventing RTV from bonding to rubber gasket? | PlasticCarsRock | S-Series Tech | 3 | 09-09-2012 11:38 PM |
SL2 Oil Pump Seals | Dale002 | S-Series Tech | 1 | 09-02-2006 04:38 PM |
SL2 Oil Pump Seals | Dale002 | L-Series Tech | 1 | 09-02-2006 09:44 AM |
Two oil pump seals things | emailer33 | S-Series General | 3 | 04-28-2005 04:04 PM |
