#21 |
![]() Join Date: Aug 2006
Take a look at this thread, several posts down.
https://www.w-body.com/topic/56443-t...-5tm60/?page=2 |
#22 |
![]() ![]() Join Date: Mar 2001
To me it just looks like a roller bearing with a seal on one side. that in itself is not all that uncommon.
Any one have the od x length x shaft size is accurate measurements? It's an Ina bearing, that would be my first stop. Highmile '95 SL1 747k and counting |
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2013
Ah, more good clues. I had read that this type trans was used in an Oldsmobile at one time, but no idea what model or year. Knowing it is a Getrag 284 should also help.
Via private email, user "cgg17" advised me the shaft is .965" OD and the bearing/seal combo is .865" long. That .965" (24.5mm?) bearing ID is the killer, not standard for either inch or metric bearings. I have suggested that a 30mm bearing could be fit in there, using a specially-fabricated (hardened and ground) sleeve on the shaft. I just don't think there is enough market to justify the cost of developing and manufacturing the "kit" that would be needed. I will look for parts relating to the Getrag 284 as time permits. |
#24 |
Well, I have been unable to confirm that the S-series manual trans is a Getrag 284 (or anything else).
#25 |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2017
1995 SW2
The saturn MP series trans is a unicorn unfortunately.
School picked up, so it is on the back burner right now. Still have to get hardness testing done. Dodge neons use a similar setup, but I did some digging and found that their bearing and housing are not close enough to work with.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018) 1994 Sl1 5spd: Inherited, Stock: 494,500 1995 Sl2 5spd: Retired Daily, Not Stock: 196,000 1995 Sw2 5spd: Daily, Stock: 105,000 |
#26 |
I thought I responded to this thread again, but I guess I never did. It took me a large number of weeks and dozens of phone calls but I finally found an MP3 out of a 97 SC2. It looked like it had been sitting outside for a number of years, but I cleaned it up and put my 5th gear swap in it from my original MP3. Just before I put it back in my 95, I looked over the quill seal and thought that it didn't look the best. But it took me so long to find just one transmission, and I needed my car, so I went with it. Things went well for a few months but my clutch is slipping again. I'm not sure if the seal is leaking again but it is making the same whining noise under acceleration that the old one did when it was leaking. I don't want to keep doing this every few months... Has there been any progress on a more permanent solution? Either that, or does anyone have an MP2 or MP3 they aren't using that I could buy? Almost all of the ones on car-part.com in my area are ones from 5+ years ago that haven't been deleted for some reason. Thanks.
1995 SC2: Back on the road again after my second engine rebuild in two years. |
#27 | |
1995 SW2
![]() Quote:
Once my semester ends, I will be removing more quills from transmissions and testing them on my stand to see if they leak. I may be able to sell some, maybe around $50? as they are quite laborious to remove in the junkyard.
#28 |
If you go to pick n pull you'll probably find a dozen lying on the ground. These transmissions are far from rare.
#29 |
1995 SW2
Not around here, a lot of S-Series are gone. I see one here and there on the road, maybe 5-10 in the yard with most being auto. The last 5 quill seals I pulled in the yard, I had to remove the trans from the car.
#30 |
Maybe outside of the Northeastern US they are plentiful. Rust sent most S-series here to the crusher 10+ years ago. There is only 1 pick and pull within a 3 hour drive of me and they have an online inventory. They have 2 S-series and both look to be automatic. All the other yards I called got rid of their s-series parts a long time ago. I can't remember the last time I saw a Gen1 Saturn in the wild since rust kills cars as new as 2012 here.
#31 | |
![]() Quote:
#32 |
Time for a bump. Any progress on this? My current transmission is driving me crazy for the same reason as the last one...
#33 |
1995 SW2
No real progress.
For fun I sent in the CAD file of the new casing that would have to be created, and was quoted over $400 alone. I am patiently waiting for my three to start leaking from the quill...
#34 |
Thanks for the update. $400 does seem pretty steep for a housing. Since I have nothing to lose I think I might try one of those stop leak seal Swellers to see if it could possibly slow down the leak. I wonder if it would also be a good idea to use as little ATF in the trans as possible so there is less liquid trying to leak.
I'm also devising a procedure to spray brake cleaner on the friction disc via the inspection cover every so often to see if I can keep it going that way. I just hate not being able to use much throttle in 5th since most of my driving is on the highway and since I have an mp2 5th it's not helping my case... I just keep hoping that someone who has long sold their Saturn finds one of these seals in a random parts box in their garage and lists it on eBay. Either that or I need to start begging people on here to sell me a low mileage mp3 because there is nothing near me.
#35 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
Could a housing be made on a lathe? Or with a CNC mill?
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
#36 | |
1995 SW2
![]() Quote:
#37 |
1995 SW2
Lathe, but the issue would be that the housing serves as the bearing race as well, so I believe some hardening would be required.
#38 |
![]() Join Date: Jan 2014
2006 ION Red Line
I'm dealing with the same issue on my 96 dohc 5 spd: leaky quill seal that eventually oiled the clutch. Funny how it used to be the dreaded diff pin that would kill these cars, now this.
Anyways, I put in some Blue Devil trans leak sealer, will see how that goes. I never lost enough trans fluid to have to add any, so hopefully the seal sweller will do it's thing. Worst case, the clutch starts slipping again, I'll just automatic swap it ![]() I mean the car started life as an automatic anyways....
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8 SL1-2. |
#39 |
![]() ![]() ![]() ![]() Join Date: Apr 2006
Location: “Is not speeding make drivers crash” ~comment by viewer of YouTube vid detailing OH Turnpike blizzard pileup 12-23-2022~
1998 SW2
Could the transmission housing be bored oversize to accept a different quill bearing from a different vehicle? Could a sleeve be pressed onto the Input Shaft?
The quill bearing is the last part to be removed when completely dismantling an S-Series transmission. Purchasing a modified transmission housing from a machinist is not unreasonable. No one would ever recoup the cost of making a quill bearing to match what’s in the S-Series now... On the other hand, an oil-soaked clutch doesn’t seem to affect my car...except for an annoying shudder while staring out, until everything is warmed-up. —Then, the friction disk engagement with the flywheel is as smooth as ever. (That is, IF an oil-soaked friction disk is what is causing the shudder) Last edited by bumpdraft; 11-20-2022 at 10:23 AM. |
#40 |
1995 SW2
http://rodneydickman.com/product_inf...roducts_id=305
Just came across this. Might be a feasible process to implement on the Quill seals. I have a bell housing apart in my basement I am going to take a look at today. Might be able to get a few pieces drawn up in CAD and 3-D printed to test it with. This would allow for the original bearing to be used, with the front seal being replaceable (which I have found an off the shelf one that will fit the housing and shaft with no machining or sleeves required). Only downside is having to drill and tap mounting holes in the bell housing case.
Bookmarks |
Subframe rot, trans output shaft seal | FireStorm102389 | Vue General | 8 | 04-30-2019 08:09 PM |
Infamous input shaft seal (quill bearing) questions I could not find answers to | The Mad Hatter | S-Series Tech | 10 | 08-19-2015 08:58 AM |
output shaft seal | dtown_50187 | S-Series Tech | 4 | 01-10-2012 11:37 PM |
Output shaft seal installation | kraz1 | S-Series Tech | 19 | 12-03-2011 09:31 AM |
How can I replace the left output shaft seal? | Brian's 04 L300 | L-Series Tech | 1 | 12-07-2010 02:13 PM |
