Old 09-21-2012, 12:30 AM   #1
ninetynineSC2
ninetynineSC2 is on a distinguished road
ninetynineSC2's Avatar
1999 SC2
Default Will this hurt my transmission?
Will I damage the transmission if I coast to stop signs in neutral? I only want to do this to improve the fuel economy by lowering the rpm's to idle since (As far as I know) The S series cars don't shut off the injectors when you coast. I know some car's won't properly lubricate the transmission when they are moving in neutral and some cars do. I thought I had read that the S series transmission is being lubricated whenever the tires are moving, but I don't know how trustworthy that site was.
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 09-21-2012, 02:11 AM   #2
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
Default Re: Will this hurt my transmission?
I'm fairly certain that most EFI cars, saturns included, have the DFCO feature.
Add to wi111y's Reputation
Rate the quality of this post and help wi111y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wi111y is offline   Reply With Quote
Old 09-21-2012, 08:14 AM   #3
jimboman
jimboman is on a distinguished road
jimboman's Avatar
2001 SW2
2005 ION-2 Sedan
I haven't read the specs myself, but I remember someone saying in another thread that the S-series have DFCO. Keep it in drive and you should be saving fuel.
Add to jimboman's Reputation
Rate the quality of this post and help jimboman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimboman is offline   Reply With Quote
Old 09-21-2012, 08:42 AM   #4
dbetz
dbetz will become famous soon enoughdbetz will become famous soon enough
1999 SW2
2000 SL
I used to do the same thing, but OldNuc and others here advised me to stop. Essentially, the constant shifting will wear out the trans and linkages faster. Not immediately fatal, but not recommended either.
The Saturns have the DFCO, which cuts fuel off to the injectors while coasting above a certain speed/rpm. So instead of using little fuel, you use *no* fuel. Below a certain speed (about 35mph for the Saturn) the injectors kick back in to prevent stalling. If you coast down and pay attention, you can actually feel the subtle change when the injectors kick back in.
Use it to your advantage coasting to stop lights/signs, on fwy off ramps, down hills to help boost your mpgs.
Thanks! David
1999 SW2 Auto 150k miles; Dark Plum Metallic
2000 SL 5-Speed 214k miles; Silver
Add to dbetz's Reputation
Rate the quality of this post and help dbetz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbetz is offline   Reply With Quote
Old 09-21-2012, 09:52 AM   #5
PlasticCarsRock
PlasticCarsRock's Avatar
1995 SL2
The gain in mileage would be very small, if any. At highway speed, there is DFCO (more related to engine speed than vehcile speed, although both will disable it when you're below whatever the limit is). On my gen1, DFCO stops once I slow below something like 1700rpm (45-50mph). If I manually downshift, the engine will stay off until you get pretty slow.
Even once DFCO stops, it's still burning very little fuel--the drivetrain is providing all the power it takes to turn the engine and accessories, so it needs just enough fuel to keep up with the air coming in (very little with the throttle and IAC mostly closed). I don't know for sure, but I expect it's less than idling in neutral (IAC opens to let in more air to power the engine and accessories).
In addition, you'll probably end up using your brakes more (without the engne braking to slow you down).
It won't really hurt the transmission, but it does mean more wear on the linkage.
I don't see any reason to do it...
High compression build: .033" shaved/ported head, flat-faced valves; gen3 rods, pistons, tie-plate; OE header, custom CAI, SDA street cams with adjustable sprockets, WBO2, SAFCII, LSD. ASE A1-A8+L1
Add to PlasticCarsRock's Reputation
Rate the quality of this post and help PlasticCarsRock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-21-2012, 09:52 AM   #6
ninetynineSC2
1999 SC2
Ok, I'll just let her coast. Now that I think about it I sometimes feel a little kick when I hit the gas after I let it coast down hills on the highway, must be the injectors re-engaging.
Old 09-21-2012, 10:47 AM   #7
alordofchaos is a jewel in the roughalordofchaos is a jewel in the roughalordofchaos is a jewel in the rough
1997 SC2
Pretty sure the Saturn transmissions stay lubricated. It was a big seling point that you could tow the Saturn with all 4 wheels on the ground behind an RV
I have a manual trans, so if I am coming up on stop and there is no traffic behind me, I will go into neutral and coast to it. No extra trans wear as I would have to take it out of gear once, and put it into gear once, either way.
...Wait, what, I actually won that eBay auction?
Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p
And now (7/2010), a Craigslist 1997 SC2 5 spd
I hurt my Aura mr weather Aura General 17 06-13-2007 08:24 PM
Did I hurt her? cindiw20 S-Series Tech 6 07-23-2005 06:34 PM
Will Prolong hurt my transmission, the guys at Bobistheoilguy thought it would. Tiger Miscellaneous Tech 7 08-09-2004 09:51 AM
Will the new look help or hurt Saturn? VTHokie00SL2 General Saturn Discussion 26 02-18-2002 01:58 AM
ouch that hurt Bryceyboy Miscellaneous Tech 5 09-15-2001 11:48 AM
