Old 09-05-2018, 01:56 PM   #1
trepetti
trepetti is on a distinguished road
Default 2001 L200 4cyl AC compressor jumper
Trying to get the compressor to engage so I can recharge the system. I see a youtube video suggesting I put 12v on pin 87 of the AC relay.
Never worked on a Saturn and never worked on AC, but I know the basics. Will check the 10a fuse on pin 30 to make sure the feed is there, then will jump that to 87 to see if the compressor engages. If it doesn't, I assume the compressor clutch is bad.
Any other advice would be appreciated.
Thanks
Add to trepetti's Reputation
Rate the quality of this post and help trepetti reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trepetti is offline   Reply With Quote
Old 09-05-2018, 04:08 PM   #2
Default Re: 2001 L200 4cyl AC compressor jumper
Are you aware that your ac system most likely leaked, leaving dye and oil markers where the leak(s) occurred? A uv light can find leaks for repairs. Unfortunately, all you're doing is refilling a leaking system. It would be wiser to find the leak(s) and make repairs. Dye was already installed and circulates permanently along with refrigerant and oil. You may find it messy using refrigerant with dye. Finding a leak doesn't require adding refrigerant but if you insist, use plain r134a (without dye or sealer).
Jumper ac relay socket terminals 30 and 87 to send power to the compressor clutch. This will get the compressor running.
Does a 2002 L200 4cyl have a MAF sensor? Babspete L-Series General 2 08-23-2015 02:54 AM
03 L200 2.2L 4cyl runs too cold ArbitraryChaos L-Series Tech 6 01-10-2014 09:24 AM
2001 L200 - Possible Broken Belt/Alternator/AC Compressor gfunke L-Series Tech 2 09-24-2010 06:57 PM
Does the 2003 L200 4cyl have a fuel cutoff switch? fgtex L-Series Tech 2 08-29-2007 09:10 PM
models with heater core compatible to 4cyl L200 angryL200owner L-Series General 0 01-17-2006 08:01 PM
