Old 07-27-2018, 11:43 AM   #1
timl865
timl865 has a spectacular aura abouttiml865 has a spectacular aura abouttiml865 has a spectacular aura about
Default 4cyl ac line replacement.
Hi, the ac line on my 02 lw200 was riddled with pinhole leaks so I cut it out. The replacement looks like I have to remove the motor mount under the air cleaner? It's that siamese hose that branches off into 2 from the fire wall. Any help is greatly appreciated! If I have to remove the mount what do I do, just jack the engine up? Thanks
Add to timl865's Reputation
Rate the quality of this post and help timl865 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
timl865 is offline   Reply With Quote
Old 07-27-2018, 11:56 AM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: 4cyl ac line replacement.
The engine can be safely jacked slightly IF and only IF a block of wood 2" X 4" or similar is used. Place the jack under the oil pan using the block of wood to rest up against the pan.
This should give you the room you need you need to remove the motor mount. Just don't jack it too high. Just enough to get the line in and out.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 07-27-2018, 12:15 PM   #3
I used online GM parts drawings for reference. The link is https://www.gmpartscenter.net/auto-p...and-lines-scat.
Old 07-27-2018, 01:21 PM   #4
timl865
Thanks for the advice but after 2 hours of struggling with that damn line in this humidity I called it quits. Who the hell thought it was a good idea to siamese an ac line like that? I couldn't route it properly so I gave up.
Old 07-27-2018, 02:21 PM   #5
rb6667
rb6667's Avatar
^^ I hear you. Been there before! This is the type of job that you do when you have a shaded area, a cooler time of the day, the right frame of mind and a lot of patience.
You'll get it done. You are wise to walk away from it for now.
Old 07-28-2018, 08:36 AM   #6
GregS&L
GregS&L is a jewel in the roughGregS&L is a jewel in the roughGregS&L is a jewel in the rough
GregS&L's Avatar
2001 L-Series 3.0L Sedan
Strongly agree! Patience and a well rested mind are your friends. I remember I slept on it that night and finished this challenge out the next day. http://www.saturnfans.com/forums/sho...d.php?t=232671
On my V6 I did not need to remove the motor mount, but your situation could be different. Removing the front right wheel helps to guide the pipes in and out.
Add to GregS&L's Reputation
Rate the quality of this post and help GregS&L reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GregS&L is offline   Reply With Quote
A/C Liquid Line Replacement Chaz9496 L-Series Tech 39 10-23-2017 09:20 PM
97 SL2 brake line replacement roberto92 S-Series Tech 13 07-22-2017 07:04 PM
Fuel Line Replacement 96 SL1 Hockey S-Series Tech 1 07-15-2015 05:29 PM
Brake line replacement...all or none??? mile2885 S-Series Tech 2 09-13-2007 10:50 PM
Fuel Line Replacement. EclecticGuy S-Series General 1 07-08-2007 02:16 AM
