#1 |
![]() Join Date: Jul 2012
Hi, I have an 05 Ion and am having an issue with where I put the key into the ignition. I've had this part replaced recently but is till causing me problems on occasion. I can put the key in, turn it forward and start the car. I've never had a problem with that. But, on occasion, when I turn the car off, rotate the key backwards, sometimes it sticks in the middle position and won't rotate back fully and allow me to remove the key.
I've recently had this "part" replaced by a local dealership, but I'm still having this problem on occasion. It is "better", but I'd think this shouldn't happen at all...ever. Any thoughts or comments about this would be greatly appreciated!! |
#2 |
We don't like Ions on this forum. Try next door --> Ion forum
MechE - I make things! EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard 1998 SL2 (gone, never forgotten) 2005 Volvo S40 T5 AWD 1987 Mercedes 300D 1993 Tracker 4x4 1996 Tracker 4x4 |
#3 | |
![]() Quote:
#4 | |
![]() Join Date: Dec 2010
2006 ION-3 Quad Coupe
![]() Quote:
![]() As for the cylinder issue, they're known for being picky. Do as Oldnuc suggested, and if it comes down to it, you may have to have it replaced again. Supposedly GM came out with a new design for it (and I hope the work is under warranty still). They usually only act up in cold weather though, so it is in all odds the key. As previously stated, have the dealer cut you a new key and it should work. Switching my key out to my spare solved the problem for me.
Elizabeth '06 Level 3 Quad Coupe. 140K as of 5-3-15. Traded for 2015 Chevy SS. Gone but not forgotten. Current: 2017 2LT/RS 50th Anniversary Camaro |
Bookmarks |
97 sl "studders" or "jerks" when turning right | chinkey1234 | S-Series Tech | 5 | 05-25-2012 11:14 PM |
Can Ignition Coil be "bad" even if tests in "good" range? | saladdin | S-Series Tech | 3 | 11-06-2011 03:08 PM |
Saturn Ion "groaning" when turning the steering wheel? | JOE PA | Ion General | 6 | 01-08-2010 02:21 PM |
3.5L water temp "fully warm" position? | ls3ftw | Vue Tech | 6 | 09-10-2009 10:08 PM |
VUE Steering wheel "popping sensation" when turning slowly | MarkW | Ion General | 6 | 06-26-2002 05:19 PM |
